Gear Oil Best Suited For V6 Tranny
Just wondering what is best suited for my tranny....
It was suggested that I use Castrol Syntec 75W90 or ATF 3, Auto Tranny fluid in a manual gearbox for the smoother shifting in the winter...
I have Delco 80W90 since I did my clutch in Nov 2005, but when I changed my axle i took the half shaft out I noticed it was a bit bubbly back at the beggining of Decemeber this year.
What are your suggestions??
- Tunes67
Royal Purple Gear oil or Redline Gear Oil (both synthetic) - You could also look in your owners manual or in the online shop manual for more specifications. Avoid Penzoil Synchromesh.. its a crappy Paraffin based gear oil.. yup.. same stuff used to make wax.
Tunes67
Tunes67
Redline works well, but pricey. $20 a bottle, and takes almost 4, or was it 5, but enough...
- mr1in6billion
Gotta be more than 3, maybe 3.5. I remember a partial bottle being used. I think i may of had an extra 5th in case.
Maybe $8us, but i believe they were $19.99 back a few years ago when i got it, but it was probably because it was the only place around with it. JRPonline is currently selling it for C$15/bottle
- mx3autozam
exactly what i told you krishTunes67 wrote:Royal Purple Gear oil or Redline Gear Oil (both synthetic)
I have Royal Purple in my tranny. I've been told you will notice smoother shifts.I don't think sowhen i did my ze swap i used Royal Purple synthetic motor oil so I used there tranny fluid. Its called Max gear. Another good one is the GM Syncromesh...i hear that stuff is awesome. honda guys swear by it!
umm..as for Mazda aying us ATF+3 that sounds wierd because +3 is for Chrysler I think. when yout motor is cold you won't get that hard shift and 2nd gear grind with ATF. Some mazda 5spd trans require atf and its required i've heard. I used to have an escort which uses a Mazda trans I think or mayabe mazda designed trans and it was like that.
You sure they said ATF+3 or was it Mercon3. thats what Fords use and Gm uses Dexron.
93 Mazda MX3 KLZE Turbo
- papa roached
the manual says something about using ATF, i never have and i have always used the el cheapo from napa, shifts great for me
- ryan_Fuerte
im using quaker state fully synthetic, works good $15/quart and take 3.
Mx-3 GSr : Rebuilt klde with 5spd swap, xtd stage 3 clutch, Magnaflow dual exhaust,Accord custom intake, kyb gr2 struts with eibach springs, civic dual halo projectors, black altezzas, white 15'' oz rims, rolling on dunlop street slicks.
http://www.cardomain.com/ride/2400330
