Hello Everyone,
I recently replaced my fuel pump with a 255 and noticed a massive drop in fuel mileage...I went from about 10km/l to 7km/l
Now to my knowledge changing the pump alone should not contribute to the drop in economy right? My O2s are in bad shape but I was getting 10km/l with the same one before the fuel pump change....any recommendations?
Thanks
Fuel Economy
Fuel Economy
Friends are just enemies who lack the testicular fortitude to kill you.
I'm a 2min man in a 1min universe
94 GS - KLZE, Spec2 Clutch, Fidanza 9lbs FW, 2 1/4 full magnaflow exhaust. 145WHP / 147WTQ
- jschrauwen
Uday, did you retain your FPR Solenoid when doing the ZE swap? If so, the new FP shouldn't be creating your mileage loss. Perhaps your FPR can't quite compete with the pressure from your new FP.....just a guess. Perhaps grabbing a second FPR from the junkyard (before they get covered in snow) might be worth a shot. Can't hurt and should be only a nickle and dime cost thing anyway.
FPR = Fuel Pressure Regulator? Well if that is what you are talking about then no I did not get a new one when I did the swap.
But I will look into getting another just to see if there was a difference.
- jschrauwen
Uday, Uday, UdaySelecta wrote:FPR = Fuel Pressure Regulator? Well if that is what you are talking about then no I did not get a new one when I did the swap.
Read what I said again. When the ZE swap was done, did you retain the Fuel Pressure Regulator Solenoid, not buy a new one. Some people ditch them during the ZE swap process or more than likely they ditch them when they do a CAI conversion. It's the Solenoid that's attached to the side of the airbox, has a wire connector and 2 vaccum lines going to it. One of those vaccum lines goes to the FPR (Fuel Pressure Regulator).
