15rims what size tire?
What kind of winter tire or all season tire will fit on the stock 15inch rim off of a 1992mx-3? I have 205/55/r15 on now but those are summer tires, what other sizes will fit?
- solo_ryder
- Tropical Emerald 1993
- Yoda
For winter I would go with a 185 over a 195 for snow and slush. The narrow width cuts through the snow rather that pushing a wedge of snow in front of the tire. the taller side walls also help to allow that time to ride over ruts in the ice as well. In winter Rally racing you often see 165 and 175/50/18"solo_ryder wrote:195/60/15 would be a good size for winter, 185/65/15 will even work, the size you got now is the OEM recommended size for the 15" rim.
The following is a general equivlent size to the stock rotational diameters
165/75/15
175/70/15
185/65/15
195/60/15
205/55/15
215/50/15
225/45/15
235/40/15
245/35/15
Also the rubber compound in "All-Season" tires really isn't much good below -10C below this temp the rubber becomes to hard and looses it's ability to grip.
I also use 195/60/15 winter tire.A year ago I used Yokohama Tire..this year I'll be trying a new one..
- ryan_Fuerte
get your self some goodyear ultra grips, there only around 70-90 a tire, and have lasted me many winters. the directional tread really gets you through the snow.
Mx-3 GSr : Rebuilt klde with 5spd swap, xtd stage 3 clutch, Magnaflow dual exhaust,Accord custom intake, kyb gr2 struts with eibach springs, civic dual halo projectors, black altezzas, white 15'' oz rims, rolling on dunlop street slicks.
http://www.cardomain.com/ride/2400330
Check this site out. http://www.rims-n-tires.com/rt_specs.jspTropical Emerald 1993 wrote:How come tires that are 205 and 185 width fit on a same 15'rim?
Different tires will fit on the same rim because the sidewall is flexible. Each rim size has it's own recommended size, but you can usually deviate 15-20 mm away from the recommended size, and the tires can still seal correctly.
Also, in snow and ice, the thinner the better, because wider tires tend to float over the ice and snow, while thinner tires will try to get between the snow. Look at the Rally cars. Their tarmac tires are way wider than their snow tires.
