i don't understand corksport anymore. not only did they send me Advanz Clear Side Markers whose holes are too tight to fit my bulbs into, their Spoiler/Kits page advertises a J-Spec Front bumper but lists the spoiler\lip for it separately, hardly showing the piece.
This is their J-Spec Presso style front bumper:
and this is their J-Spec Presso front spoiler\lip:
i don't get it. i hardly see any spoiler in the second image: it all looks like one piece ... i don't recall seeing this front bumper on any j-spec mx3's to begin with neway. I thought j-spec front bumpers are the same as e-spec:
Corksport's J-Spec Presso Front Bumper
1992 Mazda Precidia
V6 K8 Engine
V6 K8 Engine
- neutral
That is the J-Spec spoiler. Jschrauwen has it on his too.
Don't see it nearly as often as the straight-line lip. The J-Spec lip is also one continuous piece - see pic below.
There's one on ebay at the moment.
http://cgi.ebay.com/ebaymotors/JDM-OEM- ... enameZWD1V
-Jim
- papa roached
if your order their j-spec bumper its drilled for the different lip, the holes are higher so you cant use a us-spec lip on it, i know i got the lip from ebay and ordered the bumper from them
and hte lip is not one piece, it is split in the middle into two like the us-spec one
- Aston Wards
- papa roached
this style is on the Eunos Presso, a different trim level than the 30X
