OEM Piston for KLZE
- Ice Racing
OEM Piston for KLZE
I am looking for mazda original part number for klze piston. I have to install new ones (oversize). I also want to shave the heads, is 0.0040 too much?
GS KLZE FOR ICE RACING
from what i read on probe talk you can shave up to .080 off before its an interferance engine....i think corksport sells the new ZE pistons
2006 best ET 14.43 @ 96.9mph
93 MX-3 GS-95 Curveneck klze, kl-01 cammed,homemade CAI,HEI module, chipped kl-07 ECU,UDP,KYB GR-2 struts,DropZone lowering springs, Toyo Proxes 4's 205-50-r15
parts to be installed:Turbo hot pipes,T04E/t3 50/63 57 trim, ssqv BOV, hks style 38mm wastegate
the rest of my turbo set up and IPP hp rebuild kit is in the NEAR future
SOON TO BE MX-3ZE-T
SOON TO BE MX-3ZE-T
- kiwi_MX3
- Location: Backpacking in Canada in vancouver 13march onwards
mazda did'nt produce OEM oversized pistins so you will have to look
aftermarket for something.
as for shaving 0.004" off, that would not even compensate for a valve
regrind
regrind
- Ice Racing
OEM Piston for KLZE
Sorry i meant 40 thousand of an inch. I want it to be safe for racing (reliable)
One guy recently got a ZE rebuild kit from CorkSport and they came with .050 overbore pistons, Mazda OEMkiwi_MX3 wrote:mazda did'nt produce OEM oversized pistins so you will have to look aftermarket for something.
http://forums.probetalk.com/showthread.php?t=1701214996
(If it wasn't xmas time, i'd pick that up)
- JM1EC-V6
totally false. Mazda produces oversized pistons.
'94 Mx-3 GS-R SE, KL-ZE Interprep. (From '96 PGT KL)
1110Kg
-Interprep KL31 Spec.
ported heads, Polished combustion chamber,3 angle vlv job,10.3:1 C.R.,0.020'' O.S.,KL31 cam,-0.007'' heads,Long neck IM,KL31 TB, Hotshot headers,2.25'' exhaust,Magnaflow cat
1110Kg
- jschrauwen
JM1EC-V6
Gender:
I enjoyed some wild times in sister city - Bagotville
Gender:
- kiwi_MX3
John you party aniamal.jschrauwen wrote:JM1EC-V6
Gender:
- mx3autozam
Mike is taht the link i sent you?Nd4SpdSe wrote:One guy recently got a ZE rebuild kit from CorkSport and they came with .050 overbore pistons, Mazda OEMkiwi_MX3 wrote:mazda did'nt produce OEM oversized pistins so you will have to look aftermarket for something.
Thats a nice kit he ahs but thsoe are de pistons look at the dome. He claims there ze but I know there not.
93 Mazda MX3 KLZE Turbo
- Ice Racing
mx3autozam wrote:Mike is taht the link i sent you?Nd4SpdSe wrote:One guy recently got a ZE rebuild kit from CorkSport and they came with .050 overbore pistons, Mazda OEMkiwi_MX3 wrote:mazda did'nt produce OEM oversized pistins so you will have to look aftermarket for something.
How sure are you that they are not KLZE ? Can anybody check and confirm part number direct application with Mazda ?
Would bemx3autozam wrote:Mike is taht the link i sent you?
- mx3autozam
Have fun talking to Mazda about a klze. they will have no idea what it even is.Ice Racing wrote:mx3autozam wrote:Mike is taht the link i sent you?Nd4SpdSe wrote: One guy recently got a ZE rebuild kit from CorkSport and they came with .050 overbore pistons, Mazda OEM
We all know that ze pistons are flat top and de are concave.
- Ice Racing
PISTON
OK then, where can i buy regular flat top piston? not the expensive stuff but regular...
regrind
well im totally oposite iv chaved my heads to .50 made 30 more pounds and made adjustable sprokets and i compensated the timimg it worked realy nice the timing is just as stock very nice work id thinck it will work just fine ...
11.20 @120 1.58 60 ft ALL Motor KL
