Will an MX-6 2.5L clutch fit on an MX-3 ZE?
cooper_9
Post by cooper_9 »
I'm about to buy a clutch and i can get a good deal on a used one from an mx-6 2.5L, will the mx-6 2.5L clutch fit? I did a quick search and saw maybe one or two people say that it will but i just want to be sure. if it wont i'll just go with a probe one. thanks. btw the engine i will be putting in along with the clutch is the 2.5L klze.
Jay Cooper
92 Blue GS
JWMX3
Post by JWMX3 »
yes.. the probe/mx6 v6s same clutch
cooper_9
Post by cooper_9 »
thats all i needed, thanks
Jay Cooper
92 Blue GS
mxmaz
Post by mxmaz »
Dont go buying a used clutch. You can get a brand new exedy kit for $100
nope-mx3
Post by nope-mx3 »
wich clutch would be the "best" for the K8?
Not OEM, but performance.
And would it be cheaper to get one for the 2.5 vs the 1.8?
-nope
:: 2001 Mazda Mx-5 Sport // 2013 Volvo V40 D2 Momentum ::
I'm using an Mx-6 clutch, the 2.5 and 1.8 clutches are the same price, so might as well get te one for the 2.5
Mazdaracer
Post by Mazdaracer »
Some of the BP Protege guys use the 2.5 clutch as it has a bit more surface area, so that may be the case between the K8 and KL clutches too.
G series is G series :)
THINK FAST, GO RACING!!
2004 Mazda6 Wagon
2004 Mazda3 Sedan
1990 BG8P Protege LX - KLZE - Race Preped - #98 SM - SCCA Solo2
JWMX3
Post by JWMX3 »
yep the probe disc is 10mm larger diameter then the k8 clutch, they're interchangable
hppwdn
Post by hppwdn »
I have an RX7 unsprung 6 puck clutch disc with the stock K8 pressure plate on mine. been running strong for 14k miles so far.
hgallegos915
Post by hgallegos915 »
i remember shattering with the kf almost same as k8... the ze has no shatter with my stage 3 clutch.
-hec
JWMX3
Post by JWMX3 »
^^ shatter, lol
what brand of "stage 3" clutch do you have ?
my clutch chatters in reverse, it pisses me off
MazdaNoob123
Post by MazdaNoob123 »
no the clutch sizes for the mx-6, probe and mx-3 v6 are the same size.
225mm
I still cant find anywhere in the shop manual where it says there should be a 1in hole in the side of the block. (Blown K8) #6 rod thrown through block.
Steeb
Post by Steeb »
nope-mx3 wrote:wich clutch would be the "best" for the K8?
-nope
i think the best clutch for the k8 would be the stock k8 clutch. its probably a bit lighter than the 2.5 clutch which would help throttle response
nope-mx3
Post by nope-mx3 »
-nope
Well, the rest of my car is not stock, so when I`m replacing the clutch, I want to get something that`ll be ready for more power down the line.
Stock clutch here in Norway is more expensive than a ACT clutch anyway.
-nope
mx3autozam
Post by mx3autozam »
I have a 2.5L MX6 ACT stage 2 its really nice only if you can put up with a stuff pedal.
John
93 Mazda MX3 KLZE Turbo
