so today i spent it converting a 1.6 dohc mx-3 engine into a 1.6 sohc i know its a waste of time. I have a spare 1.6 sohc&trans siting in my wreck 93 MX-3 just don't want to take the time to pull it i have no turck to bring it to the shop. there a crap out sohc engine and a good working dohc.
to my surpise when taking apart the sohc bottom block they come with a windage tray i know the bp's have them didn't know the sohc had them too.
![Shocked :shock:](./images/smilies/icon_eek.gif)
anyways to convert a dohc engine into a sohc u need swap out these parts not worth the converting but i had spar parts to prove if it can be done.
1.6 sohc parts
cly. head
head gasket
water pump
oil pump (why timing tensioer on the oil pump where it on the water pump on the dohc) sohc&dohc oil pumps different
windage tray and oil filter spout and oil pan
timing belt
Pic will be post of the differnce and simlarries of the sohc and dohc engines.
