Im having some bad luck with this car, after fixing a broken trans fluid line and replacing the dist. I noticed the temp gauge got almost to the red and the fan never kicked on, and I swear I heard it working the other day.
(Mind you Ive only owned this car since wednesday)
thanks for all the help
Nick
At what point does your cooling fan kick on?
well
it sounds like you have either a broken fan....maybe you unpluged it or something when messing with the distributor or with the trans line just check your connections. if that doesn't fix it I would replace your fan
