Prix...des Parts
Prix...des Parts
Salut Salut.....
Je vien de macheter un Mx-3 4cyl et puis jai les chose suivante a changer et jaimerai savoir les prix aproximatif..!
-Cable Pour Brake a Bras
-Petit tuyau pour bypass du radiateur (metale fuite)
-Bar stabilizatrice Juste ou ya les chose en caoutchou a changer (ou au complet)
-Bushing Pour le shifter
Merci !!!!
Merci !!!!
im à l'aide d'un traducteur ici si désolé s'il ne se comprend pas. le tuyau de déviation de radiateur est $30. les douilles de levier sont $10 pour le boulon et les douilles. les liens de fin de barre de balancement sont $80 pour une paire.
Bochek
Bochek
Adam Bochek's 93 1.6L SOHC http://www.bochek.ca/car.gif
the handbreak cable, wich piece are you looking for, the front half or the rear half?
Bochek
Bochek
all these prices i picked outta my head, from previously replacing these parts. they are all rough estimates, check with a local dealer or parts supplier to be sure.w4r3z wrote:hummm not sure witch one....i know it broken but i didint avec any time to chek it maybe toomorow or this weekend
Were do you pick your price !?!?!
Thx man !
Bochek
i find the leak that i was talking about from de prestone line the guy who prevously have the car say to me that the bypass line was leaking due to rust i dinint se the hole but i put water in the line and i saw the water were that come out....the line pass just under the exaust pipe where they conect to the engine...is it an hard job to replace ?!?!? and how about the price !!?!?
Yea i will go to my local partshop...bye i work to late so they are close this weekend il'go
thx man
thx man
thx man
thx man
- BANNED Member
