Any advice would be apriciated.
Standard ecu with ZE streight neck??
Is it possible to do this with reprogramming the ecu? I drive with MAF but true ZE is with VAF... or what do i need to change? Or is it possible... (without changing the intake).
lakersfan1
lakersfan1
I'm starting to get the feeling you're not telling us everything. Are you in an English speaking country? If so, stop with the crypticly short messages and explain your entire situation. What car is this going into? What country is your car from? What engine EXACTLY do you have? What computer EXACTLY do you have?
- jschrauwen
Agreed. This is very annoying for someone who's asking for assistance. Gives a little info but not complete - thereby giving wrong impression. Wrong impression you ask?? - Profile info is incomplete (not stating location of member), No info in sig block to indicate improvements if any either. Then gives a little more info that changes the complexion slightly, but again, still not a complete story. And to top it all off, where is he going with all of this in the first place. Not to mention, all of this is well documented, numerous times and is available via a search.lakersfan1 wrote:I'm starting to get the feeling you're not telling us everything. Are you in an English speaking country? If so, stop with the crypticly short messages and explain your entire situation. What car is this going into? What country is your car from? What engine EXACTLY do you have? What computer EXACTLY do you have?
Re-cap .... J-Spec MX6 (MS8) used JE50 VAF, J-Spec Millennia (Eunos 800) used a MAF (type/# unknown to me).
lakersfan1
THis should be a moot issue as we're on an MX3 board, and there are proper ECU's available for every engine that go with the KL02 or JE50. But now that he's whipping out a picture of a MAF plug, I'm starting to think he doesn't even have an MX3.jschrauwen wrote:J-Spec Millennia (Eunos 800) used a MAF (type/# unknown to me).[/color]
sorry if i sound iritating to you it was not my intention.
I thought all KFZE engines use MAF system so i wanted to see if someone had to do rewiring when dropping Enos KLZE (maf) or KFZE in you'r mx3 as the procedure would be the same just reversed.
I have a lantis 2.0 KFZE v6 (European). And dropped KLZE in the car. It runs ok whith standard ecu (KF 77 ECU) but to get full peak power of ze i must afcourse intall the kl31/36 with je50. The problem is that im not shoure if i did the connections right as the car behaves strange. (runs rich and idles weary bad)
When i compare the ECU connections of an standard kf77 ecu with mx3 its almost identical. There are some small diferences with A/C batery lights and sfcourse maf/vaf differences.
Or is it easier to get complete wiring harness from mx3 and install it?
- kiwi_MX3
- Location: Backpacking in Canada in vancouver 13march onwards
Ok lets get this straight for five minutes
the engine ECU loom for a Maf is different for a Vaf.
you can't just go and splice it up to suit a different sensor
and wack in another ecu and hope it runs fine.
So the engine ran fine with your KF77 ecu and your Maf.
You have since tried to install a kl31/36 and Vaf and it runs
like Poo!
Edited.
Try searching MS window switch's as the main differnce between
Ecu's and intakes is when the virs points open and close.
like Poo!
Edited.
Thats KFZE MAF connections VS JE50
