VW Rabbit Commercial
- JWMX3
2007 Rabbit specs :
Engine
Type 2.5L, 5 cylinder, in-line
Bore 82.5 mm
Stroke 92.8 mm
Displacement 2,480 cm3
Compression Ratio 9.5:1
Horsepower (SAE) @ rpm 150 @ 5,000
Maximum torque, lbs - ft @ rpm 170 @ 3,750
Fuel Requirement Regular unleaded
Firing Order 1-2-4-5-3
Engine Design
Arrangement Front mounted, transverse
Cylinder Block Cast iron
Crank Shaft Steel, six main bearings
Cylinder Head Aluminum alloy, cross flow
Valve Train Double overhead camshaft, chain driven with automatic tensioner, four valves per cylinder, maintenance free hydraulic lifters, single coil valve springs
Cooling System Water cooled, water pump, cross flow radiator, double electric PWM controlled radiator fan
Lubrication External gear pump, chain driven, oil cooler
Fuel / Air Supply Sequential multi-point fuel injection (Motronic)
140 amp alternator, and 4 wheel disc brakes too
weight - 1349 kg = 2974 lbs
Engine
Bore 82.5 mm
Stroke 92.8 mm
Engine Design
![Image](http://img40.imageshack.us/img40/7481/avatarmx.png)
- XxantwawnxX
wow 2974 pounds...figured it would be light. Well i guess that is light compared to todays cars.
![Image](http://members.cox.net/antwawnhayes/Mx3comavatar.jpg)
Considering how safe VW's are suppose to be, that's not that bad.
- Tunes67
Doesnt matter what you do to it.. it will always be a VW. As Foghorn Leghorn was once quoted as saying "I say son.. you can, I say you can son, polish a turd, but in the end.. you just have a shiny turd"
LOL
Tunes67
Tunes67
"So long.. and thanks for all the fish!" "Momma says VW Bugs are the devil" "This one time at band camp.. I stuck a flute in my Throttle Body" ![Wink ;)](./images/smilies/icon_wink.gif)
Volkswagons rule i love them and unforunally by next year i'll no longer have the mx anymore she is going to be getting upgraded to a 1999 VW Jetta or Golf ( haven't decided if i want to go back to having a trunk again)
don't get me wrong i love the mx it's just not very practical for me anymore. i orginally got my mx because i couldn't afford gas back and forth to burilington on a 94 ranger wouldn't have been so bad if it didn't have the 4.1L under the hood. but at last i need a car that seats more than just Two (don't care what anyone says the back seats are for emerengcy and show use only !!!!! unless your friends are midgets!!)
Reaper
Reaper
![Image](http://i81.photobucket.com/albums/j214/reaperofsouls2001/winterx-90.jpg)
- solo_ryder
- XxantwawnxX
Yea the first 2 went in to the tunnle to "breed" (rabbits) white and black. So some that came out was spotted : )solo_ryder wrote:Anyone notice the multipanaled - colored one?
- MechaManZero
That commercial was pretty catchy lmao.
Çlark
![Image](http://i64.photobucket.com/albums/h192/Mechamanzero/MX-3/2mx3.jpg)
95 Mazda MX3 4 Banger
Currently: H&R Lowering springs, BPT from a GTR, 18.5x6x3.5 same side inlet and outlet intercooler, Centerforce Dual Friction clutch
For BPT Frorums - http://www.aokforums.com/mazdaengines/
I love this commercial, it is catchy and very well done...so i had to download the song. BTW It's "The birds and the bees" by" Patrick and Eugene"
- Hoodzy
who wants to mate with my car
shes sexy!!!
shes sexy!!!
1995 Creek Mica Blue GS
compared to the older rabbits, the newer ones are a dissapointments. Rabbits were the s--- back in the day, i had a rabbit cabrio and that was one of the best and one of the funnest vehicles i've owned.
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
