KL-ZE
can you do it, yes, can you do it easy, no.
you need the whole v6 front subframe and tranny, as well as the wiring harness, ecu, and all the other v6 specific parts, it just isnt worth the time, when you can get a bpt for a few bucks more and make a few more ponies.
Bochek
Bochek
Adam Bochek's 93 1.6L SOHC http://www.bochek.ca/car.gif
No need to swap subframes.... thats a myth.Bochek wrote:can you do it, yes, can you do it easy, no.
Bochek
Engine
Tranny
axles
ECU
Engine harness
Engine Acessories
3 of 4 engine mounts and brackets
...and probably some other small crap I am forgetting.... only reccomended if you have a donor car or a plethra of Mx-3's at a j/y.
I know this b/c I swapped a BP into a Mx-3 GS. If you have done a B series swap in a civic its kinda aloong the same lines... it has alot of little crap that you need that can mess you up... but if your good with your hands you'll be fine.
GS + BP + T3 + 9lb flywheel - some dead weight =
- Limegreen mx-3
did u swap the crossmember and motor mount bracket (to that of the 4cly model) that what i did to a BP in a GS MX-3 racingmazda 475whp@18psiD323 wrote:
Engine
Tranny
axles
ECU
Engine harness
Engine Acessories
