Wierd Pipe Setup on V6
http://www.cardomain.com/ride/2330498
anyone else think this is a wierd piping setup, is that bend not reducing ALOT of flow?
http://www.cardomain.com/ride/2385931/4
Car Name - Elsie (LC)
Car Type - 92 Black RS Stock 190k
Car Name - (yet to be decided)
Car Type - 93 (soon Black) GS KLZE 130k
- MechaManZero
Nice setup. Nice kit. Not a big fan of the wing though lol. you should have gotten the mazda stock raised spoiler... would've looked classier with that kit.
Çlark
![Image](http://i64.photobucket.com/albums/h192/Mechamanzero/MX-3/2mx3.jpg)
95 Mazda MX3 4 Banger
Currently: H&R Lowering springs, BPT from a GTR, 18.5x6x3.5 same side inlet and outlet intercooler, Centerforce Dual Friction clutch
For BPT Frorums - http://www.aokforums.com/mazdaengines/
- PATDIESEL
That is not LooseChange's car, you can tell from the plates.
I've heard that it is not so much the degree of one bend, but the total degree of all bends added together that makes a difference. That is not a fact and I've not been able to find a definate answer on it, but that is what I was told once. However, that bend does look pretty extreme.
- MechaManZero
i dont care if it is a mazda speed lol those high wings look horrid. ![Razz :P](./images/smilies/icon_razz.gif)
Çlark
- XxantwawnxX
i think that wing looks decent on the mx3...but not super....heh lotsa better choices.
![Image](http://members.cox.net/antwawnhayes/Mx3comavatar.jpg)
- babyblueMX3
we have no choice with our v6. With the turbo sitting high beside the disty, the compressor outlet and the intercooler outlet (or inlet depending on the wich side you're using as an inlet) is FAR from each other.my piping length was similar to that just behind the rad instead of in front.cjthor wrote:Man who else has like 32 feet of intercooler piping??
Solution to this : both inlet and outlet on the same side
RIP 400whp ZE-T MX-3
the wing is lame. grill looks good but y not just put a ram air at the end of the intercooler and not worry about the bend?
[fs] 92 MX3 gs 2.5 klze v6, Intake, Exhaust,drop zone spring{awsome},Turbo, Splitfire plugs, fmu, gauges ,drilled slotted rotors ,motegi rims,tires,Blackout lights, and a nut behind the wheel~~ so far.
- BuGS
You guys are so weird. What I would do is get a full SS exhaust then go:babyblueMX3 wrote:we have no choice with our v6. With the turbo sitting high beside the disty, the compressor outlet and the intercooler outlet (or inlet depending on the wich side you're using as an inlet) is FAR from each other.my piping length was similar to that just behind the rad instead of in front.cjthor wrote:Man who else has like 32 feet of intercooler piping??
Turbo-pipe-water injection nozzle-pipe-tb
you guy still insist you guys "need" ICs, when you don't. Look at most of the turbocharged drag cars, they have water and alcohol injection...
- babyblueMX3
water injection is good for drag cars. it's just not pratical for everyday use. I don't see myself filling a water/alcool tank every day !BuGS wrote:You guys are so weird. What I would do is get a full SS exhaust then go:babyblueMX3 wrote:we have no choice with our v6. With the turbo sitting high beside the disty, the compressor outlet and the intercooler outlet (or inlet depending on the wich side you're using as an inlet) is FAR from each other.my piping length was similar to that just behind the rad instead of in front.cjthor wrote:Man who else has like 32 feet of intercooler piping??
- XxantwawnxX
I prob have about 5-6 feet of intercooler pipe the way i did mine..im to lazy to measure probabaly even less.
- BuGS
Who says you need to fill it everyday?? A tank of water with water injection lasts you about 2 fill ups of gas. And then all you use is the Windshield washing fluid, just the 50/50 mix without any detergents and you are set. There are numurous RX7 guys using it because you get like 5 degree C air instead of close to 30 degrees C...babyblueMX3 wrote:water injection is good for drag cars. it's just not pratical for everyday use. I don't see myself filling a water/alcool tank every day !BuGS wrote:You guys are so weird. What I would do is get a full SS exhaust then go:babyblueMX3 wrote: we have no choice with our v6. With the turbo sitting high beside the disty, the compressor outlet and the intercooler outlet (or inlet depending on the wich side you're using as an inlet) is FAR from each other.my piping length was similar to that just behind the rad instead of in front.
So, it is not just for drag cars. and BTW, I live in a Muscle town City where there are 100s of fixed up muscle cars. Most of them use water injection with their supercharged cars so they can push 500+whp out of a small block 350 and still drive them everyday without blowing the engine...
