Head light problem
mrspanky79
Head light problem
Post by mrspanky79 »
OK here is the problem last year my passanger light stop working on me. I have changed bulbs still dosnt work, the high beam work but not the driving light if i rember right last year I back probed the plug to see if i was getting power and i was i will retest tomarrow. Any one else have any ideas and things to look for while im under there tomarrow.
War does not determine who is right, war determine who is left!
94 mx3 GSX Stroked Turbo'd and Intercooled
99 vitara 4x4
mrspanky79
bump
99 vitara 4x4
ariesdude
Post by ariesdude »
If you are getting power - then change the bulbs again and make sure you get the right bulb(9004), right wattage etc. It might also help to clean the contacts a bit...
94 Mx-3 Precidia
Custommx3
Site Administrator
Post by Custommx3 »
FYI, using overpowered bulbs can burn up a harness. Local guy here put in too high wattage bulbs and fried his 2x alread. Went back to stock bulbs, never had an issue.
mrspanky79
problem sovled and yes i was using stock bulbs. I feel like a real dumb a$$ the problem started last year just before i put it away for the winter. I had 3 spare bulbs tried them all had the same resaults. Well i retried the 3 today and turns 2 was bad and one was good some how tried one twice. Anyways on the next problem, boost controller :confused2:
99 vitara 4x4
