O2 Sensors
- Paylrider
O2 Sensors
I am replacing my O2 sensors and was surprised to see the cost of the original ones, I noted several universal O2 sensors, with two to four wires and you attach the connectors, are these recommended or has anyone used them?
I converted to 4 wire universal sensor in my 4 cyl - no problems. If you are afraid of cutting/splicing wires then it may not be for you.
94 Mx-3 Precidia
the ebay ones i got came with some weird instructions - a 4 wire sensor has 2 same colored wires (usually black) for the heater and one wire for the sensor signal (usually blue) and one wire for the sensor ground (usually white).
94 Mx-3 Precidia
