Dash light on intermittingly
Its a 1992 mx-3 v6.
The dash light on the top left part of the cluster. I really have no idea what its for. It really doesn't look like anything. I'm going to assume its the alternator light maybe? Ever since I had the car, it would go on first thing in the morning when it was still cold but only for a couple secs. Now, its starting to show up at idle but goes out when I start to rev the motor. Any help?
Also, where can I buy a new air filter online? The parts stores don't carry them. I put new plugs in and banged out my air filter and my gas milage went up to 30, from 26ish.
- PATDIESEL
Barry is still right. You need to check, clean and maybe replace the battery cables. They wear out over time and it is about time based on the car's age. A poorly functioning alt will also give a light. The fact that it does it when cold and only when at idle only stregnthens the reason to check the cables first then the alt, then the battery.
yes, top left light is the CEL (Check-Engine Light)
my question is: if the CEL comes on randomly, perhaps days between these times, for like 4 seconds each, does that mean the problem isn't serious? is the warning phony? why would it come on so barely unnoticed if its supposed to be a warning?????
are there times when the CEL comes on and stays on for like an hour? coz i've never seen that...
sorry, i have nothing to compare to. All I ever get with any of the cluster warning lights are 5-second come-on's, then they just go off for a day, and come back on the next day for 3 seconds again like a constipated employee.... i duno. my auto repair for dummies book doesn't cover this question for me ...
1992 Mazda Precidia
V6 K8 Engine
V6 K8 Engine
- tehbrookzorz
squampton? i guess u mean esquimalt.. no, i don't live there.. neway
hey, could you answer my question? intermittent dashlight vs solid dashlight? i only ever see intermittent dashlights, more like random, whenever it feels like coming on, which i don't know how urgent of a warning that is. doesn't seem like it
1992 Mazda Precidia
V6 K8 Engine
V6 K8 Engine
- tehbrookzorz
I can't really answer based on that one without some research. Anytime I've had the check engine light so far has been related to a faulty ignition module. The light would come on just as the car started to die, and then I'd turn the key off, so I'm not sure if it was a flash or solid.
At any rate, have you pulled codes? Your car is OBD1 like mine.
This might help, but the server is slow as hell.
http://ca.briefcase.yahoo.com/bc/c_t_br ... -3&.view=l
Cody
![Image](http://i.imgur.com/Q0Vh17N.jpg)
