uk owners section map register
- garfy1981
just a trial to see if it picks up, but the plan is to have a map based register of the uk mx-3 owners as i expect some of the uk owners section are no longer mx-3 owners. It also is a quick quide to see if any mx-3 owners are local to you.
should help setting up future uk mx-3 meets.
http://www.frappr.com/ukmazdamx3owners
2.5 Ze straight neck, blitz intake, mazdaspeed engine mounts, fidenza flywheel, CM II Clutch, KL-36 ecu, Magnecor 8mm Leads, Battery Relocation. Hotshot headers, 2.5 mandrel bent stainless exhaust, hi-flow cat, Speed hut dials, custom coilover set up. Custom willwood big brake conversion.
- garfy1981
cheers mate, if the idea takes off were try and get this made into a "sticky"
so far added garfy1981
badmx3
badmx3
- rsroadkilla
- rsroadkilla
- garfy1981
we have 4 members so far !!
- garfy1981
hi ya anne, thought i close map due to lack of interest ???? but im glad some other uk mx-3 owners showed interest.
- Aiden Ulph
If anyone is interested I've just created a myspace group and added a map there.
You can find it here: http://groups.myspace.com/ukmx3owners
original link not working
original posted wed address is 'url not found'
21m sw london, mazda mx3 1.8 v6 1993 carribean turquoise blue.
