ZE IM for my DE?
ZE IM for my DE?
I'm thinking of getting a ZE curved neck IM for my DE.
*Will it be ok to use my DE VAF and ECU?
*Is it worth spending $200 on this upgrade. I have no other ZE parts such as heads, cams or pistons. After summer I may be interested in ZE cams though.
*Can I use the DE throttle body? The IM I'm buying is complete with injectors and all hardware except the TB.
Inputs please.
One of the reasons that I want a ZE IM is that I then can use the stock air box. I'm not a fan of my CAI I have at the moment ending up behind the head light scrathing against the chassis.
Inputs please.
i wouldnt....zes are a hit and a miss, $600 is the cheapest ull find unless u get a good deal on the boards+install, plus few things u might want to upgrade/replace ie. timing belt, water pump, oil pump, afpr, ze ecu. clutch, flywheel, motormounts....itll be enuf money for a decent engine, so if u want the small performance gain then the im is fine, ull have to do some modding to the vacuum line if ur using usdm tbRacerX wrote:
I'd say save the money for a complete ZE, 200.00 is almost half way to owning one
- Custom_V6_Limited_SE
Is there a difference other than pistons between the DE bottom end and the ZE bottom end?
'93 MX-3 GS SE:My Mods
- jschrauwen
Re: ZE IM for my DE?
Macen, a couple of issues to possibly consider;Macen wrote:I'm thinking of getting a ZE curved neck IM for my DE.
Inputs please.
De has "D" shaped ports where as the Eunos800 IM (curverd neck ZE) is square, so there's a port matching and gasket issue to contend with.
I can't see using a DE VAF and ECU since they will not be in sync with the VRIS or the injector sizes. You may actually have a decrease in effectiveness wrt VRIS and with the injectors, you may encounter an extremely rich condition since the ecu is thinking it's driving DE injectors instead. The ZE injectors are larger than the DE, I believe.
So, in essance, if you're still committed toa ZE IM, you would need a ZE ECU, the JE50 VAF and also the KL68 (or similar) TB. If it were me, the cost and expense in this particular case would not be justified. Perhaps if you acquired ZE cams, than it may be a more worthwhile venture showing noticable power gains. As it is, you would be overloading the engine's capabilities without doing a cam upgrade first. Adding all of these items ===> Cams, IM, TB, VAF, ECU etc would almost cost the same as sourcing a complete ZE, even in your country, I would think. Just my $.02 though.
John
- JWMX3
they are the same injectors, 220s but you were right about everything else as usualjschrauwen wrote:[ The ZE injectors are larger than the DE, I believe.
- jschrauwen
Thanks Joe......... duhhhhhh!!! I had my Millennia 290cc injectors in the back of my mind somehow. Hope this didn't make a huge difference for Macen though *fingers crossed*JWMX3 wrote:they are the same injectors, 220s but you were right about everything else as usualjschrauwen wrote:[ The ZE injectors are larger than the DE, I believe.
- jschrauwen
Here's the trick Macen. Last Feb Spinkx79 and I went to Tiger Japanese an importer in Toronto. There were numerous MS8's and Eunos800's there. Some of each of them came with tranny's. The Eunos800's that did have tranny's were all ATX's whereas the MS8's had MTX tranny's. I had then separate the MTX tranny from the MS8 engine which I had pseudo tested by had to confirm if it was an lsd. I have no idea of the percentages as to how many of the MTX's on the MS8's were LSD. I believe it was an option on the MS8 and not a standard config, but not %100 on that. Tiger Japanese will ship just about anywaher and may be cheaper from Canada than the states (just guessing here). If you are of a mind to contact them looking for only an LSD you might be into a real mess since they may not be able to discern which from which and the cost for the tranny alone would be nearly the same as a whole engine. If your really serious about it, you could have basically a whole engine [MS8] and tranny shipped to you. The problem would of course be the straight neck [long neck] IM as being an issue for the LHD vehicles. HOWEVER, if a deal is struck for a complete engine and tranny, THEN have them separate an MS8 tranny and attach it to the Eunos800 engine before shipping. Maybe and extra 50 to 75 bucks for their effort. You could quite possibly end up with an LSD and you could sell the ZE engine alone and have a bit of extra cash in your pocket. Just for numbers sake...say $1,000cdn for ZE alone and $500 for the tranny alone ad opposed to about $1,300 or so for a complete engineand tranny. They do ship worldwide I believe because they do sell on ebay also. Perhaps a Toronto member could earmark a tranny and engine for you so that they won't try and screw you you or give you a DE in disguise. Food for thought.
The Millenia S Miller-Cycle Supercharged 2.3L KJ has the larger injectors.jschrauwen wrote:Thanks Joe......... duhhhhhh!!! I had my Millennia 290cc injectors in the back of my mind somehow. Hope this didn't make a huge difference for Macen though *fingers crossed*JWMX3 wrote:they are the same injectors, 220s but you were right about everything else as usualjschrauwen wrote:[ The ZE injectors are larger than the DE, I believe.
Thanks again John. I wonder how much I will have to pay for shipping though. I like your idea about getting an engine and a tranny and then sell the ZE to someone here in Sweden or Norway. nope is interested in a ZE, but I also know others here.
Yeah, the problem will be getting the correct LSD without being screwed. Maybe you have some good reliable contacts? It didn't happen much with the group buy on those LSD trannies.
- jschrauwen
I thought I'd throw that out there for what it's worth. It's something that I'd probably consider. As far as actually having them confirm that it's an LSD, your dialogue with them should not reflect the value of an LSD but rather get them to agree with you that the Tranny's from the MS8's are ALL LSD"s and in that way they won'tfeel compelled to try and charge you more. if you catch where I'm coming from. Her's their link; http://www.tigerjapanese.com/Macen wrote:Thanks again John. I wonder how much I will have to pay for shipping though. I like your idea about getting an engine and a tranny and then sell the ZE to someone here in Sweden or Norway. nope is interested in a ZE, but I also know others here.
I imagine you'll need to establish some correspondance with them first to get the ball on the roll. Last time I was there, there was about a 8 or 9 ZE's there. As far as lucking into an LSD, it could be just that - LUCK
