sticking rear brakes
hgallegos915
Post by hgallegos915 »
I checked my brakes..the hand brake was sticking a bit the brakes. i removed it and ok... i noticed and think one of my rear calipers is sorta seizing..its dirveable but i get ALOT of rear brake wear and alot of brake dust.. hmm any ideas on how it can be fixed or how i can tell? its making my car slooooow i get around 20 mpg now.. hmmm i think i gor 21 today.
-hec
stereoking15
Post by stereoking15 »
it's real easy to dismount the caliper and check for sufficient free play in the caliper slide pins. also as well one of the slide pins is an automatically lubricating one so you should not have too many problems with it i just did 4 wheel brembos with kvr carbon fibre pads and had both front calipers seized which took a lot of finese to free up and my rears were not to terribly bad but once apart you can lubricate the slide pins with either sil glyde brand lube or a synthetic brake grease prefferbly made by crc which can be had at just about any knowledgeable napa auto parts store.
94 gs ze swapped,front mount oil cooler,b&g springs, kyb gr2 struts, vris deleted, gutted, racing 4 point harness. centerforce dual friction clutch, BREMBO ROTORS X4, CARBOTECH XP10 front pads, ebc green stuff rear PADS, corksport brake lines & clutch line, hei mod w/ msd blaster 3, MAZDASPEED motor mounts, B&M short shifter, M-FACTORY LSD, Carbon fiber hatch with lexan window.
sxetechie51666
Post by sxetechie51666 »
i ended up having to just take it to the local shop where i get all my work done, and they had to completely replace the hand brake cable, the calipers, the discs, the pads, it cost over 600$ US
I dont have my seat, i gave it away already
i loved my mx3, but i dont have one anymore, so i wont be on here anymore
lakersfan1
Post by lakersfan1 »
This is why you need to grease your calipers every single solitary time you take them off, even if it's just an inspection. What I do, is after I unload the pads, I press the brake pedal once or twice to make the caliper piston come most the way out. Then, I take and grease the snot out of the sides as far down as I can get, then recompress it back into the caliper. Never had a siezed caliper, ever.
stereoking15
that my friend is not a wise thing to do because if you are talking about greasing the caliper by pulling back the rubber sealing boot and shooting grease in there is a bad idea because you do not want a petroleum product anywhere near brake fluid and on top of that what happens when you start getting some wear on the piston? it will start getting in the grease because the fluid is right there on the back side of the piston hoping that the rear seal is not bad so that you get grease all in the system.
