Still got overheating problems
Has any one come across a problem with the coolant being push into the over flow bottle.
- XxantwawnxX
there is no fan belt, now water pump belt is the one you wanna check. The one that goes to powersteering also. Does it run , do you have white smoke coming out the tail end or oil in you coolant? Check themostat.sonue1 wrote:Fan belt fine.Is it posible [or common] for the headgasket to blow between water ports?
A bit more info on the over heating,I have fitted a new water pump,fitted a new tstat thinking that was the problem still happend so removed the tstat,had radiator cleaned,flushed the motor replaced coolant. Checked compresion all cylinders running 210PSI varies by 1or2PSI checked temp switch and sensor all ok .Temp only rises after car has been driven or idle for about 20min ,and only stays up near the hot marker for about 1 min then goes back to halfway,then continues to rise and fall.but the water in the overflow bottle is not hot. No the engine has not overheated.AND typing error on my part saying FAN belt...
oh man, i am in the exact same boat as you.. haven't cehcked compression yet. i hope it's something as simple as a new rad cap or tstat... i'll be sure to let you know when lakersfan1 helps me get to the bottom of it.
from what he said though, I would gather that if your compression's ok, you don't need to worry about the head gaskets. that's a big plus.
Water still too hot...
I am still racking my brains over my overheating problem...
Can nobody give me any ideas!
Looks like my heads sre coming off..
- Philthy
Before you pull the heads do some some teting, Use "block check" to test for CO in the cooling system, take temp readings at tstat outlet, inlet to radiator and outlet from radiator. Pull a heater hose and run briefly to check flow of coolant. Also monitor how your fans cycle in relation to your temp. PS rule of thumb radiator should drop 20deg. across itself. Higher drops can indicate low flow i.e. stuck tstat, blockage (BARS Leak and ALUMA-SEAL ARE THE DEVIL!), bad coolant pump. Block tests works great if you don't want to buy the kit you could talk a shop into running just that test fairly cheap. Good luck!
92 MX-3 GS, KL-ZE, OBX headers, 2-1/2" exhaust, XL Performance muffler, AASCO Aluminum flywheel,Pheno spacers,APEXi Airflow computer,Eibach springs,Tockico struts, Toyo RA1 205/50ZR15s, B&M short shifter. MS control arm Bushings, SS clutch line, SS brake hoses
Just a quick note to let everybody know that the over heating problem was due to a blocked radiator...
I had the radiator cleaned.
But after all the problems I was having I decided to check the water capacity of the radiator and found that it was still only about 40% of what it should be.
So hopefully it will be trouble free running till the next problem.......
