Well i want more power
Im looking to get ~250whp.
What in your opinion is the cheepest way of doing so?
I dont have much money, but the car is just too damn slow.
i was thinking a bpt but thoes cost a bundle.
I might have a opertunity to get a kl-de really really cheep, but thats not for sure yet.
Besides i have the 4cyl so the kl swap is a big task in its self.
What about a b6t? where do i get one? how much power will they put out?
Thanks for all your help,
Bochek
Bochek
- Limegreen mx-3
hate to say it to u but if u want power ur going to have to put some cash down. go for a plain and simple N/A BP there sort of cheap 200-700 and its better then the 1.6 sohc or dohc.
- Josh
its not the best by any means, but its the cheepest. definatly start with a BP, its really the only way to go, you will be starting out 20 hp ahead. and if you got alittle more you could go and swap yourself in a Pro LX trans at the same time. or for like 1200 bucks you could pick yourself up a BPT and sometimes they are attached to a trans ( if your lucky). but if you bought an N/A BP then pieced your own kit together that would be the cheepest. the stock BPT lays about 170 hp to the crank on stock boost, and a turbo N/A BP can throw down 180 to the wheels on stock psi. so its pretty easily done for under 2500 bucks total, getting good parts. now going with wrecking yard parts, you might be able to do it for 1500 pretty easily.
- TREVO123
Ya but if you get a BPT it has better internals then the regular plain jane N/A BP just my opinionfieromx3 wrote:yea i wouldnt get a bpt just get a n/a BP and peice ur own turbo kit together and major work
- Josh
Rods only, followed with sodium valves, and lover compression. a good N/A BP will take almost as much abuse, its good if your only planning to boost 15psi, any more and i woulent feel safe. but a BPT i would probably boost to 20. i know the rods fall out after 30psi. but Bugs boosted to 30 on his N/A BP, and that was the braking point for the N/A rods, so i would say if your going to build a junkyard turbo kit starting out with a good N/A BP would be the best rout. because stock for stock with boost you will be starting out with more power.TREVO123 wrote:Ya but if you get a BPT it has better internals then the regular plain jane N/A BP just my opinionfieromx3 wrote:yea i wouldnt get a bpt just get a n/a BP and peice ur own turbo kit together and major work
- Limegreen mx-3
u'll get more power out of a turbo than u will out of a supercharger.
not entirely true a turbo will add more power at higher rpms but for off the line acceleration supercharger all the way instane boost no spolling requiredLimegreen mx-3 wrote:u'll get more power out of a turbo than u will out of a supercharger.
but in the end the supercharger / turbo debate is all personal preferance
but starting off with a turbo bp is the cheaper way in the long run even if you don't run it with the turbo hooked up and na headers
you'll still be starting off with better interals,and injectors just make sure you get the higher flowing fuel pump aswell
![Image](http://i81.photobucket.com/albums/j214/reaperofsouls2001/winterx-90.jpg)
I just have to say this becuase it seems fitting, but this is not entirely true either. It is very possible to setup or tune a supercharger or turbo charger for various parts of the powerband. Centrifical superchargers are often not effective at lower RPMS, where as roots blowers are what is more commonly thought of in terms of supercharging.reaper of souls wrote:not entirely true a turbo will add more power at higher rpms but for off the line acceleration supercharger all the way instane boost no spolling requiredLimegreen mx-3 wrote:u'll get more power out of a turbo than u will out of a supercharger.
Freqently OEM's use tiny turbos to give low end grunt but wheeze when it comes in terms of the top end, all in all it just depends on how you desing you setup.
Pick your power band, then pick your parts to get it.
-torp.
I don't own a Mazda.
