walbro 255 lph hp fule pump info
JWMotorsports
Your welcome....I wish I had more time to help you all out on a regular basis! I pop in whenever I get a chance which usually isn't really often.
JWMotorsports
The RX-7 and Cosmo pumps work as well. For Higher volume needs I recommend a fuel cell, -8an lines, and the Accel DFI 110FI fuel pump (110 gal/hr, 416lph, 880pph).
