difference between a kl36,kl31, and a kl46 ecu?
- stereoking15
what is the advantage or disadvantage to running any of these ecu's? wich one has the best overall performance and capabilities for the mx3 wit ha klze swap running obd1? input would be appreciated
94 gs ze swapped,front mount oil cooler,b&g springs, kyb gr2 struts, vris deleted, gutted, racing 4 point harness. centerforce dual friction clutch, BREMBO ROTORS X4, CARBOTECH XP10 front pads, ebc green stuff rear PADS, corksport brake lines & clutch line, hei mod w/ msd blaster 3, MAZDASPEED motor mounts, B&M short shifter, M-FACTORY LSD, Carbon fiber hatch with lexan window.
- PATDIESEL
The difference is the fuel maps and VRIS points. The best ECU for your ZE will be the one that matches your version of the ZE.
So, the way to tell what ZE you have is by the throttle body number. It is stamped on the top of the TB.
Mixing and matching will cause a decrease in power.
- Tunes67
Bah!! Dont bother with the ECU's.. stay with your K8 ECU and run a piggy back fuel management system. That way you can still pull all your error codes simply.. the cost is the same and you get better performance for the money spent.
Tunes67
Tunes67
"So long.. and thanks for all the fish!" "Momma says VW Bugs are the devil" "This one time at band camp.. I stuck a flute in my Throttle Body" ![Wink ;)](./images/smilies/icon_wink.gif)
i wouldnt say the cost is the same tunes, its a little bit more to go piggyback thats what i plan on doing and im using a kl31 ecu
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- Tunes67
Guess that kinda depends though man.. I have seen people on e-bay pay $400 for a KL31 (and yeah I laughed too LOL). I did generalize.. but you got a good deal on your ECU and not everyone will get that good of deal man ![Wink ;)](./images/smilies/icon_wink.gif)
Tunes67
Tunes67
