clock and temperature guage dont work?
- misfitsfiend
anyone know what the reasons behind this can be.. i tried looking on the online manual but not all the pictures show up
- jschrauwen
Try Grant's site for an aplicable wiring schematic and go over that. You haven't mentioned what you've tried or not tried yet or how this all came about - ie, the circumstances that led up to this - or is it a somewhat embarrassing story?
Fuses????
http://www.eunos30x.com
Fuses????
Ya jschrauwen good call. I hadn't responded because the temp gauge isn't tied to any electrical circuit as such. As we know it operates from a thermocouple and the clock problem can only be totally unrelated unless its a cluster issue (highly unlikely but open to comfirmation).
The temp gauge should work with a dash power problem and vice versa. So more info is needed to even start guessing. Unless of course the plug to the cluster (1 of 4) has come out.
- misfitsfiend
well i dunno what happend.. i know its not the guage cluster.. cuz i used two different clusters so far.. and the same thing happens
and all i know what happend was i pulled out hte first cluster to put on some of those slip on guage faces... and well i plugged it back up and the two things didnt work... i figured maybe one of the wires maybe slipped out of the plug but they are all in place.. so i dont know what else it could be...
If you have a look at the diagram here:
http://eunos30x.com/info/1993%20Wiring%20Diagrams.pdf
Figure 9.
Assuming everything else is working its a bit of a mystery as they're not really interconnected. Are you sure EVERYTHING else is ok?
Figure 9.
Did you check all the fuses? The fuses sometime look ok but are actually blown - so just visually checking them is not enough.
Are you sure that the tachometer (RPM) and fuel gauge are working properly?
94 Mx-3 Precidia
- misfitsfiend
- misfitsfiend
Try spraying some contact cleaners on the sockets ....
From the circuit diagrams - you know what color wires are connected to those things - so try and test those wires with a multimeter. (You can probably borrow a multimeter from an auto parts store).
I am purely guessing here - but if the signal from the thermo sensor is ok - then the BLK-ORG wire for the temp gauge should probably have 0 volts when the engine is cold and should be above 0 volts when the engine is hot.
Check the wires for the clock - i am guessing they should all have +12v except for ground (BLK-GRN) and 2L (RED).
94 Mx-3 Precidia
