Alberta Oil Jobs
Alberta Oil Jobs
Hey does anyone know how to get a job in Albertas oil sands?
i donno my ex gfs dad and brother are out there working.... my cousin is an oil rig engineer near sylvan lake i believe its called.... i donno i can see what companies they work for and let you know?
95 rs with custom short ram air, b&m short throw shifter, probe 2.0L header with 2 1/4" exhaust all the way back, catco high flow cat, apc high flow muffler with 4.5" tip, accel 8 mm wires, blaze red, cf altezzas, gun metal 17" mr7s, slotted cross drilled rotors on the way with hawk hps pads, red and white interior, other then that its stock.
- Franko
I had an alberta oil job once.. I think its kind of like a cleveland steamer except you can choose what kind of oil you want to use.. I chose tropical orange.. I recomend it.
![Image](http://i17.tinypic.com/30idc09.jpg)
- Flashpoint2
I work in the Alberta Oil and Gas industry
93 GS, KLZE, KL31 ECU, Centerforce Stg 3 Clutch, 2.25" Exhaust w/Flowmaster muffler, OBX Headers, Pheno Spacers, Front & rear X-drilled/slotted Rotors, KVR pads, SS brake & clutch lines, Ractive Filter, H&R Springs, Tokico Blue Struts, 8mm Accel Wires, MSD 6A w/ Blaster 2 Coil, HVAC Indiglo Panel. *Sold*
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
Re: Alberta Oil Jobs
Same way you get a job anywhere else. Try halliburton.mr_icez wrote:Hey does anyone know how to get a job in Albertas oil sands?
