mx6 turbo fit a mx3
mx6 turbo fit a mx3
i can get a turbo off a mx6 (not sure the year) and wanted to know if it will fit my 94 mx3 1.6 dohc? any one knows let me know please!
- Aston Wards
If you have a 1.8liter v6 engine. The 93-97 probe 2.5L v6 engine will fit ,
However neither the earlier year probes 2.2's or the 93-97 2.0's will fit in the 4cylinder version of the mx-3 ..
I know your new but there is a search button that lingers on top of the page
^^^^^^^^^^^^^you can hit it anytime ^^^^^^^^^^^^
93 Kandy Tangerine Mx3 GS-DE
02 Subaru Impreza OBS
& Lots of Toys to haul
No, the 1st gen Probe's/626/Mx-6 uses an F-series 2.2L SOHC engine. It's the same engine found in the Mazda B-series trucks and is not compatiblewith the B-Series I4 that your Mx-3 uses. To swap that engine it, it will require all custom work, and custom=$$$. Although it will require some wiring work, a BP/BPT would be much, much easier than trying to install than putting in an F-series motor.
For the turbo, the exhaust manifold shouldn't match up at all. The turbo you can use (EZ_4_FUN is using that turbo on his ZE), but as Joey's Mx said (although I don't know enough to confirm it), you'll beed the turbo exhaust manifold from 323GTX (I'm guessing the B6T) to be able to bolt that turbo to the engine.
- babyblueMX3
no they don't make onek-town bmx wrote:thinks. do they make a twin turbo mx-3 or was the guy telling this to me lying and if so i can get one for around $500
RIP 400whp ZE-T MX-3
so what your saying is since i have a 4cyl a 2.5 probe gt wont fit? if not than what type of motor could i get to have around the same power as a prob gt engine?
no motor will fit ur car to get 164hp like the probe gt motors...
but wut u can put is a bp motor that gives 130hp
Peter
Re: .
wut r u talking about?papadeez15 wrote:never heard of it...
does it fit the mx3 gs?
how much power do u get?
vj11 is the stock turbo that 1st gen mx6's and probes use, itll fit on almost any motor with the right accesories(manifold being the main concern)
k-town bmx wrote:so what your saying is since i have a 4cyl a 2.5 probe gt wont fit? if not than what type of motor could i get to have around the same power as a prob gt engine?
The 2.5L V6 engine out of a Probe/Mx-6/626/Millenia is a direct bolt in to the V6 Mx-3 because they are all from the same series of engines (K-series), but that is the only engine from a Probe that will fit; the 2.0L 4cyl or the 2.2/2.2L turbo from the 1st generation Probe will not fit.
If you have a 4cyl Mx-3, no matter if you have the 92-93 SOHC or 94+ DOHC, you basically have to convert your 4cyl to a V6 Mx-3, and when that's ready, you can use any V6 engine from an Mx-3, Mx-6, 626, Probe or Millenia (excluding the Millenia S Supercharged 2.3L KJ). K-series V6 engines vary from 130hp to 200hp
Because of the work involved to convert a 4cyl Mx-3 to a V6, it could be less work and more likely less expensive to upgrade to a bigger 4cyl. What is known as a BP is a 1.8L 4cyl that you can find in Escorts, 323's and Protege's. That engine is 130hp, roughly the same power a the 1.8L V6 that the Mx-3 comes with. Because you have a DOHC 1.6L, it will require some rewiring, but it's still very doable. Putting in a V6 will require some wiring, and then some. So for ease, this would probably be the best bet.
Now, you want with something of roughtly the same power as a stock Probe 2.5L KLDE; 164hp. Well, up from the 130hp from the 1.8L BP 4cyl engine, you have 2 other choices, their turbo versions, the GTX @ 180hp, and the rare GTR @ 210hp. These motors were found in Mazda 323's and Protege's. Or if you want to take it one step at a time, you can start with just the 130hp BP, and turbo it later, that's commonly done.
Now, if you want to turbo your stock DOHC motor. It's been done a few times and you'll have to ask around. Basically, you can use pretty much any turbo from any make and model car and engine, you just need a way to bolt it to the engine. You can make your own if you want to, but Joey's mx mentioned that all you need is the exhaust manifold from a Mazda 323GTX. I may need to be corrected on this, but I believe he's probably talking about the manifold from the B6T version in the first GTX's, since I believe that the BP would be too big/wide to bolt up, but I may be wrong
