Underdrive pulley
- mx3autozam
Underdrive pulley
What does everyone think about a Underdrive pulley. I know you need to trim metal from the oil pump housing but my deal is there is no harmonic balancer on it like the OEM one has. And some people wills ay it w8ill give me more problems than Its worth. Any truth to this
The one I ahve is the Unorthodox Racing pulley made from aluminum
93 Mazda MX3 KLZE Turbo
- hppwdn
I had one on my Probe and on my MX3. Never had any problems because of it. I don't have a giant stereo or anything that pulls a lot of juice at idle though.
- mx3autozam
- babyblueMX3
yup no problem here too, been running with one since 3 yearshppwdn wrote:I had one on my Probe and on my MX3. Never had any problems because of it. I don't have a giant stereo or anything that pulls a lot of juice at idle though.
RIP 400whp ZE-T MX-3
None the lighten flywheel doesnt add any hp, it allows for more bhp to be sent to the wheels from the motor. As we all know you loose somewhere around 20-30% of hp from transition from BHP to WHP. adding a lighten flywheel, underdrive pulley, stronger motor mounts (mazdaspeed, urethane filled, or solid) allows for that % to decrease. You can also remove parts to decrease that % even further, Such as AC and even an alternator (NOTE you would only remove your alternator if the car was 100% ment for drag, as your battery would die very quickly).shawno wrote:Hey i no the lightened flywheel how much hp does it add to the car.
Now according to some if you were to go with the combo of a Lighten Underdrive pulley and Lighten Flywheel you would need to have your crank balanced to the new parts, because there is a chance you could be rubbing against your bearings because of the addition of the lighter parts. For someone runnning alot of Hp this theory makes since.
As for the having problems with a lighten underdrive pulley, I've ran one and never had a problem with it.
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- kiwi_MX3
- Location: Backpacking in Canada in vancouver 13march onwards
Ok these are pic's of my new "under" drive pulley,
the water pump will be the same size 100mm in diameter
and the alternator about 60mm.
Im not dragging a power steering pump or a AC pump.
You do not need your crank balanced if you change the flywheel or
pulleys that is a myth as they are rotational parts.
The only time you need to do a check balance or balance the crank
is when you change to a heavier ROD and piston Combo.
Also the KLZE\ K8's are triple plane motors bascily two three clyinder
motors on a common crank....
My crank timming ring is the same size as standard though ive set mine
up not on a rising trigger which the standard ecu run's as im running
aftermarket.
excuse the large pic's works camera not mine.
aftermarket.
Actually it's 110amp and they are Millenia alternators, you should be able to get them from any parts place or even a junk yard. For what I remember however is that only the earlier years had them, later I think they moved down to the 90amps like the GSmx3autozam wrote:was just talking to a mx6 guy and he said they not bad on our cars provided we use the right belts and possibl;y a JDM 120amp alternator. I might even swap over alternators when i install it.
John
