I have the white/power wires from the Volt and W. Temp Gauges spliced and sent to the dimmer switch. The ground wires are spliced as well and sent to the frame of the car. Now...the power/red wires for the Volt, W. Temp, and Air/Fuel are spliced and sent to the ciggarette lighter power wire. The sender wires/purple for A/F is spliced into the blue/red wire on the O2 sensor... The sender wire for the W. Temp I had spliced and sent to the white(or faded blue)&red wire on the water temp sensor.
The results
When I turn the key to the "on" position the volt meter goes up to 8 volts, and the others do nothing...I crank the car up turn on the lights, when I turn the dimmers down the guage lights get brighter and vice versa. And the A/F guage...lets just says it does nothing but just relax in the pod. Please if someone could tell me what to do...Here is to show you some sort fo Diagram of my wiring scheme. I am sorry it is so small but photobucket shrunk it. I can email the full size if someone is willing to help me.
~Jay
![Image](http://i51.photobucket.com/albums/f397/jyounya/AUTOMETERSCHEMATIC.jpg)
