Klze Mx3 breaking axles
Alright heres the deal. My car is either evil or I need to get heavier duty axles because for the second time it has claimed the life of a young axle. Last time I was taking a turn gettin off the highway doin like 5 mph and the knuckle shattered inside the boot. This time I was taking a turn and there was a loud grinding noise and the car would barely move. Today I jacked it up and had a friend got the wheels rollin while I looked to see what the deal was. The driver side was barely moving and the passenger side was flyin. So I thought this meant something was wrong with the driver side. I grabbed the axle and tried to move it back and forth nothin... This seemed wierd to me cuz last time it was broke I could move it. Anyway, I set the car down and tried to move it a little. The car suddenly sank down. Got out and took a look and my driverside wheel was at a nasty angle and the boot was ripped at the transmission. The axle was hanging down knuckle and all. Also upon further inspection the ball joint had seperated itself from the hub assembly. Not sure how that one happened. The axles have a lifetime warranty but I"m getting tired of replacing them. I have never had a problem like this before this car so I'm wondering whats up. (Axles are from napa). Why is my car eating axles like bon bons?
92 GS, 210 psi per cylinder KL-101 Engine, Pacesetter Exhaust, Centerforce DF, CAI, Hi Flow Cat, Headers.
By Spring 06: Megasquirt and FPR
By Fall 06: KL-31 Heads with Interprep Cams
- jschrauwen
I'm just starting to get to that stage now - axle selection. Try a search from Gro Harlem and Kiwi_ _ _. Try using axle or spline as a search parameter.
What tranny are you using with the ZE - ZE, MX3, PGT, MX6, LSD?
ATX or MTX?
ATX or MTX?
I would say its the luck of the draw, with those lifetime axles. I bought a set and snapped it in a couple shifts. The last set i got i have made several 12 sec passes, 5500 RPM dumps on slicks on a 75 shot of nitrous. And i have yet to break one.
I actually just broke my 3rd gear the other day jamming out on the bottle and then shifting to 3rd. So now i need another tranny, but the axles are just fine.![Laughing :lol:](./images/smilies/icon_lol.gif)
- XxantwawnxX
Never had a prob with my stock axels and my ze.
![Image](http://members.cox.net/antwawnhayes/Mx3comavatar.jpg)
- stereoking15
how low of a drop do you have? have you had any damage the the front suspension lately? i have the napa axles in my mx just in the past months and have been doing wonderfully!! granted it is still a k8ze but i push mine through autocrosses on a weekly basis and didnt have problems until the second to last race when both boots ripped (stock axles) and i push my car most everyday and still fine, are they actually napa branded or are they and ari axle that they sell?
94 gs ze swapped,front mount oil cooler,b&g springs, kyb gr2 struts, vris deleted, gutted, racing 4 point harness. centerforce dual friction clutch, BREMBO ROTORS X4, CARBOTECH XP10 front pads, ebc green stuff rear PADS, corksport brake lines & clutch line, hei mod w/ msd blaster 3, MAZDASPEED motor mounts, B&M short shifter, M-FACTORY LSD, Carbon fiber hatch with lexan window.
What you just described is your ball joint falling apart. What does this have to do with an axle?
Replace it, no big deal.
I have 400 whp and all I broke in 20k miles was 3rd gear. Stripped the teeth clean, axles were fine.
Id rather have an axle break. Easier to replace than a tranny. And you can rest assured that the trans is going to break.
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
I knew I had to replace the ball joint. However, the boot was also ripped and the knuckle was pulled out of the transmission. This doesn't seem like a typical problem so I figured i'd make a post. Is there a possibility this happened because when the ball joint came disconnected it yanked the axle out from the weight of the car? Are you runnin stock axles with 400hp if so where you get them from because these don't seem to be cutting it. Also my car is not lowered.
- XxantwawnxX
I drive pretty hard. Maybe my tires are not sticky enough.Bochek wrote:then u dont drive hard enoughXxantwawnxX wrote:Never had a prob with my stock axels and my ze.
- relisys_3200
Yeah its a possibility. Theres no way for it to pull out when your suspension is together, the tripot won't clear the cup to fall out. That would in turn rip the boot after it fell out though.ProjekMX3 wrote:I knew I had to replace the ball joint. However, the boot was also ripped and the knuckle was pulled out of the transmission. This doesn't seem like a typical problem so I figured i'd make a post. Is there a possibility this happened because when the ball joint came disconnected it yanked the axle out from the weight of the car? Are you runnin stock axles with 400hp if so where you get them from because these don't seem to be cutting it. Also my car is not lowered.
The axles I have are stock ones. I ripped the boot on the drivers side when I installed it, negated fixing it, and ruined the inner joint. I bought a CCT lifetime axle (autozone/advanced auto) for the drivers now. Be sure to reuse your clip on the side that goes into the tranny, those remans have clips that like to get stuck.
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
- PATDIESEL
Sounds like you got a wron axle. There are several different axles fo rthe Mx-3 depending on year and motor (SOHC + DOHC 4 bangers and DOHC V-6) If you got a four banger DOHC axle and fit it into a V6 application it could be that the axle was too short and caused the CV joint to seperate. I measured the axles legnth trying to figure out which axles were for which car when I bought several crates full of Mx-3 parts. The difference was small between all of the axles for both DOHC motors, so small that I couldn't be sure I was correct and so I didn't sell any of them. I dount seriously that a correct axle would fall apart enough to pull out and tear through the boot.
On a sie note, not all Napa axles are remanned at the same place. They will have a mutitude of different shops that remann axles that they buy from. Maybe your local rebuilder is an idiot and put the axle together wrong or labeled it wrong.
Hmm, I've been using Canadian Tire remans since my ZE swap over 2 years ago and I haven't shapped one or needed to replace one for whatever reason
