CAI Vibrant
CAI Vibrant
Can i use Vibrant CAI kit for Acura Integra (90-93) #2207 ?
I can order cai just from catalogs.
Thanks
Thanks
1997 MX-3 1.8 V6
- jschrauwen
Re: CAI Vibrant
Attach a pic of the item you're describing and someone should be able to recognize if it will work. Most of use buy it from ebay because it is so much cheaper there.Gorlm2 wrote:Can i use Vibrant CAI kit for Acura Integra (90-93) #2207 ? I can order cai just from catalogs.
Thanks
Yes, you can use it
93 GS, KLZE, KL31 ECU, Centerforce Stg 3 Clutch, 2.25" Exhaust w/Flowmaster muffler, OBX Headers, Pheno Spacers, Front & rear X-drilled/slotted Rotors, KVR pads, SS brake & clutch lines, Ractive Filter, H&R Springs, Tokico Blue Struts, 8mm Accel Wires, MSD 6A w/ Blaster 2 Coil, HVAC Indiglo Panel. *Sold*
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
- jschrauwen
OK, plan "B". Hopefully this CAI is in an electronic catalogue and if so, just attach a link to that catalogue page so that we can go from there.Gorlm2 wrote:It is the problem. I don't have any picture, so i'm asking youI'm from Russia? so i can't use Ebay.
- JWMX3
Re: CAI Vibrant
yes, that one is the most common, also 90-93 accord works, either way you have to be prepared to cut it up to fitGorlm2 wrote:Can i use Vibrant CAI kit for Acura Integra (90-93) #2207 ?
Thanks
![Image](http://img40.imageshack.us/img40/7481/avatarmx.png)
- MX3 GSR for dummies
You order the CAI for the fancy piping, thats all. You'll have to cut and fabricate the intake by using sleeves you can find to fit the TB to the piping and put our MAF midway. You would also have to choose a filter for the end. Total pieces would include 1 acura (I used a 92) intake pipe cut in half. 2.5 to 3" sleeve for TB and a 3" sleeve to transfer from pipe to MAF on filter side. Direct fit the pipe onto the MAF on TB side. You also need 5 ring clips to attach and hold parts together. A mounting bracket from engine to the intake is necessary to hold and support the intake so it moves with engine. PM me if you want pics to get a visual.
If at first you don't succeed....it never happened
94 mx3 GS w/ KLZE, KL31 ECU, clutchmaster stage 3, cross drilled rotors, Custom ram air intake, Custom exhaust, Toyo tires, 250LPH fuel pump, Modified Distributor, Upgraded Wiring etc, external HEI, Full Body Drift kit and freshly painted Grey. Interior neon accents and much more in progress
Just to be picky, it's a VAF, nota a MAF.MX3 GSR for dummies wrote:You order the CAI for the fancy piping, thats all. You'll have to cut and fabricate the intake by using sleeves you can find to fit the TB to the piping and put our MAF midway. You would also have to choose a filter for the end. Total pieces would include 1 acura (I used a 92) intake pipe cut in half. 2.5 to 3" sleeve for TB and a 3" sleeve to transfer from pipe to MAF on filter side. Direct fit the pipe onto the MAF on TB side. You also need 5 ring clips to attach and hold parts together. A mounting bracket from engine to the intake is necessary to hold and support the intake so it moves with engine. PM me if you want pics to get a visual.
LOL....I didn't even realize. ![Laughing :lol:](./images/smilies/icon_lol.gif)
The link to the catalog is http://www.vibrantperformance.com/produ ... g42-43.pdfjschrauwen wrote:OK, plan "B". Hopefully this CAI is in an electronic catalogue and if so, just attach a link to that catalogue page so that we can go from there.Gorlm2 wrote:It is the problem. I don't have any picture, so i'm asking youI'm from Russia? so i can't use Ebay.
but there are no any pics for this model.
One more question, what size of adapters for both sides of VAF (difficult sentence
1997 MX-3 1.8 V6
