Did anyone do the Big Three with their MX-3?
- Mazdaspeed96743
- FlyVFR
I wouldn't sweat it. I would do what I can and the remainder I'd have done by pro installers.
BTW- 1200W RMS
That's a lot of rumble.
Good luck![Exclamation :!:](./images/smilies/icon_exclaim.gif)
BTW- 1200W RMS
![Shocked :shock:](./images/smilies/icon_eek.gif)
Good luck
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
81 Trans AM NASCAR Pace Car
80 Trans Am INDY Pace Car
www.MyMX3.com Domain For Sale!
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
- FlyVFR
Just saw this.
I would use a thicker wire to ground the battery (-) terminal.
Mazdaspeed96743 wrote:Okay but like I said earlier I am only running 8G ground wires to do the BIG 2. I hope this help my system from skipping due to voltage drops.
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
- Mazdaspeed96743
Yeah I know I have to buy me some 4G wires soon.FlyVFR wrote:Just saw this.
- Mazdaspeed96743
- FlyVFR
With that kind of power who needs a piston engineMazdaspeed96743 wrote: lol! Yeah my amp is tuned at 35HZ and I am hitting 144.3DB with one 12 playing music.
![Question :?:](./images/smilies/icon_question.gif)
BTW-Make sure you at least use ear protection.
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
- Mazdaspeed96743
- Shades
Haha I did a "BIG 3" and didn't even know it.
4G is the only way to go... I use that for power and for ground.
Also the fuse should be no further than 6" away from the battery terminal.
![Image](http://i491.photobucket.com/albums/rr275/Spudsicles/BannerFx.jpg)
"Do it ONCE, do it RIGHT!"
- FlyVFR
Shades wrote:4G is the only way to go... I use that for power and for ground.
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
- Mazdaspeed96743
Capacitors don't actually ddo all that much, unless you get the PG power block, which is a 25 farad block. (you can start a car with that thing)
I'm running 1400 watts in alpine stereo equipment and I don't have a cap -- and I'm fine, in my line of work, the only time i see the deck shut off is because of the battery being low in charge. best bet is to:
Continue with plans to use 4AWG wire. check your alternator output, make sure it's charging properly.
Also, (if you have enough spare) run a 4AWG straight from your amp ground to your NEG(-) battery post (over the seats to start) see if it still does it, you might just have a poor ground so the amp isn't getting it's full fill of current.
also what kind of head unit do you have running?
- FlyVFR
25 fards is a bit of overkill for some systems, but can't hurt. Onother way to do it is to add a 2nd battery! Caps work well if the value needed is calculated correctly and installed properly.mxtr3m3 wrote:Capacitors don't actually ddo all that much, unless you get the PG power block, which is a 25 farad block. (you can start a car with that thing)
mxtr3m3 wrote:I'm running 1400 watts in alpine stereo equipment and I don't have a cap -- and I'm fine, in my line of work, the only time i see the deck shut off is because of the battery being low in charge.
Well the MX-3 GS only has a 90 Amp Alt.
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
- garfy1981
if your battery is located in the boot for say Ze engine, what is the min size cable to use and what should this ideally be fused at ??
2.5 Ze straight neck, blitz intake, mazdaspeed engine mounts, fidenza flywheel, CM II Clutch, KL-36 ecu, Magnecor 8mm Leads, Battery Relocation. Hotshot headers, 2.5 mandrel bent stainless exhaust, hi-flow cat, Speed hut dials, custom coilover set up. Custom willwood big brake conversion.
- Mazdaspeed96743
