96 automatic transmission
I've heard the auto transmissions on the MX3's have problems. Is this true for a 96 year model as well or did Mazda make any changes to correct the problems?
96 MX3 ATX 1.6L
- Josh
they are just weak. as long as you keep up your general maint. and dont thrash on it it will be fine. one thing most forgit is the fluid and filter really should be changed every 30 to 60 thousand miles
the only reason i blew mine was because i turbocharged it.
