O2 sensors...4 wire or 3 wire uni's?
I have had bad O2's for a long time and finally ordered some. I wasnt sure if i needed 4 wire, 3 wires or both (universals) so i bought 4 of each.
They came in today.
Anyone know off the top of their head which would be better? I believe the 4th wire is only a second heated wire.
My car is OBDII (96 GS)
Thanks
They came in today.
Thanks
- jschrauwen
You got 4 of them Eric? Sh*t, I've only got 2 in mine (4 wire type). Can't really say if the OBD II changed over to a different config. I remember seeing a thread about some members integrating the universal units to our cars including the correct colour code assignments. I thought you were going to go Wideband?
Have you started to assemble the "Super DE"?
arent those extra wires for the oxygen sensor heater for cold starts? i was reading an article somewhere about those wires..forgot where
-hec
Basically ya, to get them upto temperature faster to give the ECU a proper reading. Mine were 4 wires, and so were my stock ones...i spliced the wires from the new 02 sensors and cut off and used the connectors from the stock sensors do they'll just clip right inhgallegos915 wrote:arent those extra wires for the oxygen sensor heater for cold starts? i was reading an article somewhere about those wires..forgot where
- FlyVFR
Good Just match up the wire colors or is there another trick to it? Where is a good place to buy? Are the Bosh units any good?Nd4SpdSe wrote:...i spliced the wires from the new 02 sensors and cut off and used the connectors from the stock sensors do they'll just clip right in
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
81 Trans AM NASCAR Pace Car
80 Trans Am INDY Pace Car
www.MyMX3.com Domain For Sale!
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
- jschrauwen
Being from the Us, this might be the best/least expensive source.FlyVFR wrote:Good Just match up the wire colors or is there another trick to it? Where is a good place to buy? Are the Bosh units any good?Nd4SpdSe wrote:...i spliced the wires from the new 02 sensors and cut off and used the connectors from the stock sensors do they'll just clip right in
Nopi Online - http://www.nopionline.com/nopistore/dsp ... N=35613893
973+0269 is the universal replacement for us. A search will reveal that I posted a number part numbers from Nopi Online wrt interchangability and compatibility with the MX6/626 O2's.
I wish we could get that sort of pricing up here. Usually 2 to 3 times more expensive before exchange rate and after all of the middleman's hands get a piece of it.
$42.87usd is pretty damn cheap if you ask me. Good luck.
*John*
Is it a WOXOF day out east? ....LOL
- jschrauwen
Eric, does your OBD II utilize the 3 wire and if so I'll buy the 4 wire ones off you. I think the 3 wire ones can also be rigged to work on the 4 wire applications (OBD I) also IIRC.Spinkx79 wrote:I bought "borg-warner" 4 of each kind and paid only $20 per.
- FlyVFR
Thanks John. I will check out the NOPI products.
It's actually VFR weather. Baro 30.33 at 50ft, 18.5 F, 49% humidity and unlimited visibility here in CT .....LOL
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
- jschrauwen
CAVOKFlyVFR wrote:Thanks John. I will check out the NOPI products.
- FlyVFR
Roger...Cloud and Visibility OK.
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
Atlthough i did them in spring, I don't remember the wiring colors, but I believe there was a diagram in the box to way which ones connects to which color...FlyVFR wrote:Good Just match up the wire colors or is there another trick to it? Where is a good place to buy? Are the Bosh units any good?Nd4SpdSe wrote:...i spliced the wires from the new 02 sensors and cut off and used the connectors from the stock sensors do they'll just clip right in
John,jschrauwen wrote: Eric, does your OBD II utilize the 3 wire and if so I'll buy the 4 wire ones off you.[/color]
Why would you want the 4 wire ones, you dont drive your car in the winter so the second heated wire would be of no benefit to you...IIRC
I havent had a chance to check which ones i need or will be using.
- FlyVFR
Thanks Nd4SpdSe. My first time changing the sensors after 186,000 mies I'm looking forward to better gas mileage.
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
