need rising rate FPR??
babyblueMX3
Post by babyblueMX3 »
after
it has to be the last thing in your fuel return line
RIP 400whp ZE-T MX-3
rukick
Post by rukick »
Get your facts straight. Not all FMU's are RRFPR. FMU does not always equal RRFPR. Like I said "they are different."
Turbo 94 Protege LX
babyblueMX3
fmu is just a different term to say rising rate fuel pressure regulator. (like the last link I poste)
it's the same thing, and does the exact same thing.
back on topic
rukick
Post by rukick »
babyblueMX3 wrote:fmu is just a different term to say rising rate fuel pressure regulator. (like the last link I poste)
back on topic
This is on topic. No it is not the exact same thing and no fmu is not just a different term to say RRFPR. If you tell someone that FMU is the exact same thing as a RRFPR and they go out and buy a FMU, they might not have bought a RRFPR FMU. A RRFPR is a FMU true, but not all FMU's are rising rate fuel pressure regulators. Same as then term “computer” and “laptop” are not exactly the same. Just because you go out and buy a computer does not mean that you have a bought a laptop. I am sure that you understood this difference but when giving someone advice you should be specific so they don't buy the wrong thing. That is why I posted that link and that is why I am trying to explain the difference in these two terms.
Turbo 94 Protege LX
babyblueMX3
rukick wrote: A RRFPR is a FMU true, ...
rukick wrote:This is what you want: RRFPR is different from FMU.
http://www.bellengineering.net/Pages/products_FPR.html
My main point was yes a rrpfr is a fmu and never said the opposite
This is what I said on the first page
babyblueMX3 wrote: rrfpr = fmu
so we are agreeing on that point.
but ya a fmu (fuel management unit) can be something else.
but your my 2 first quote are contradictive don't you think ?
rukick
Post by rukick »
No they are not contradictory statements. As I stated before, the terms rrfpr and fmu are different in the same way that the terms laptop and computer are different. To say "rrfpr = fmu" is misleading. It implies that these terms are "exactly the same." I am trying to point out that they are in fact different, so that he does not buy the wrong thing.
Turbo 94 Protege LX
babyblueMX3
then explain to me why cartech is mixing these 2 terms all the time like if they meant the same, they know what they are talking about, they've been in the game longer than we've been born
and 99.9% of the time, when people talk about a fmu they refer to a rrpfr.
Go to a speed shop, ask for a fmu, they'll give you a rrfpr
I think we are arguing for nothing.
rukick
Post by rukick »
babyblueMX3 wrote:I think we are arguing for nothing.
I'll drink to that. We have made our points and he'll get the right thing now for sure.
Turbo 94 Protege LX
XxantwawnxX
Post by XxantwawnxX »
A RRFPR ISSSSS A FUEL MANAGEMENT UNIT (FMU) DONE AND SAID!
now not all FMU's are rrfpr..there.
EDIT: ah i see you gusy already kissed and made up...im always late. :lol:
Joey's mx
Post by Joey's mx »
Ok so what do I get a RRFPR or a FMU?? HAHAHA just kinding guys!!! DIdnt mean to cause so much arguing!!! But thanks to everyone for there imput!!
Post by Josh »
i drilled out my stock FPR so it flows straight threw. and then im running a MSD adjustable boost sensitave FPR it works great for low boost applications but once i get up to or past 15psi it doesent work so great. so this meand i need to throw on my Comptec FMU, is to pretty.
Return to “Forced Induction”
