Got My Colt Cams =)
Got My Colt Cams =)
Got my Colt Cams Turbo cams yesterday, they look nice, i compared them to my KL31 Cams and the peaks seem a little steeper (if that makes sense).
Anyhoo...another step closer.
- jschrauwen
- XxantwawnxX
Nice, love when stuff comes on my doorstep for my MX3.
![Image](http://members.cox.net/antwawnhayes/Mx3comavatar.jpg)
- kiwi_MX3
- Location: Backpacking in Canada in vancouver 13march onwards
Well your not far wrong on that, the "D" part.fieromx3 wrote:might sound dumb but is there a way fir u to take a pic for comparison?
Eric, can you quote the cam spec's for this poor misguided
gentleman above, ie Lift, Duration, and open/closing.
- babyblueMX3
I have a 5MB digital cam but i dont think it could show you anything.fieromx3 wrote:might sound dumb but is there a way fir u to take a pic for comparison?
Colt Performance Turbo
INT: 210°@ .050 .355 Lift
EX: 200° @ .050 .350 Lift
KL03.……………………....….I/E 0.338" lift, 196-198@0.050"
J-Spec...............................200° @ .050 .350 Lift
Colt Performance NA .................210° @ .050 .355 Lift
Colt Performance Turbo............INT: 210°@ .050 .355 Lift
...........................................EX: 200° @ .050 .350 Lift
COLT RACE GRIND...................218° @ .050 .363 LIFT
based on those specs.... I have to ask, what are you gaining?Spinkx79 wrote:I have a 5MB digital cam but i dont think it could show you anything.fieromx3 wrote:might sound dumb but is there a way fir u to take a pic for comparison?
10 deg duration @ .050 and .005 lift -INTAKE ONLY is what it looks like to me. Are you sure can that be seen with the naked eye?
I know a little duration goes a long way, but I was always under the impression that on a boosted application, the exhaust lift is the most important spec. To get the old charge out of there faster and have more exhaust velocity, IIRC.
I am not flaming them in any way. On paper it seems to me like
more boost (if possible) would be a more effective solution.
Granted, I am coming from the 2-valve turbo with a SOHC world...
How much were these cams?
93 White MX-3 "Ebay special"
94 Green 626 V6 5-speed "family car"
94 Mazda B2300 SE "project turbo truk"
- babyblueMX3
the position of the exhaust changed on the exhaust cams.
That's what Geoff (colt cams) said to me, that ze cams are not suitable for best performance on a turbo engine.
RIP 400whp ZE-T MX-3
yea that's what I was kinda figuring - profile change and event change. It's good that these are mild as well. I guess I would love to see the cam card and compare it to the ZE cam. One day I'll get out the degree-ing set and try to degree in the KL03 cams and see where the events on there fall.babyblueMX3 wrote:the position of the exhaust changed on the exhaust cams.
Anybody know of a degree wheel that will work on the KLs?
- babyblueMX3
Answer from Geoff:ikarus1 wrote:I am not flaming them in any way. On paper it seems to me like
"We have increased the duration by 12° @ .050 per lobe. On a 2 valve engine this might not be that noticable.
People have stated that the J.Spec with only 20° more duation plus .015 Lift gives a noticable increase.
So the 12° X 2 is good. If I thought the 218° grind was more streetable I would push that."
Hope that helps =)
