Help with Wheel Noise
Anyone have experience with this<P>Its a noise that i hear driving from at low speeds (could happen at high too but i dont hear it). Its a "clickity" noise that almost sounds like its coming from my mirrors but i tried to hold the mirror while driving and it was still constant. I'm thinking its something in the susp., but while doing a visual check everything seems ok.<P>I had my axles repl. about 18 months ago and its not cv noise as far as i can tell. It only happens when i drive straight and it doesnt occur all the time. At first it was just the right side but now its both.
Shaun Newman
Re: Help with Wheel Noise
is it when you drive regular or only when you turn cuz it does that only when i turn at low speeds but i dunno what is is
its only when i drive straight
Shaun Newman
direct quote from the 1996 Lemon Aid Used Car Guide.<P>"A front-end snapping noise during tight turns at walking speed is probably caused by excessive clearence betwen the wheel bearing and steering knuckle. Install modified wheel bearings."<P>There ya go, other people had the problem to.
prasie the lowered
Matt - He said when he drives straight, that says when you turn.
My bad<P>I was talking to the second guy, sorry for not explaining that. He said it only happens when he turns.
prasie the lowered
