boost and the Vris system?
XxantwawnxX
Post by XxantwawnxX »
Anything i need to know about the vris system underboost? thanx again.(not sure but i think the search function is not working, i typed boost in the forced induction section and got nothing...)
PATDIESEL
Post by PATDIESEL »
Some still use it and some don't. Most who boost more than about 5 pounds remove it since it is going to hinder the boost. However, since I'm not boosted I have no idea if you use the rear bank or the front when you lock the VRIS down on way or the other.
XxantwawnxX
Hey thanx alot! Hopefully somone with exp can give some light on the issue. but i doubt im going more then 4-5 psi so maybe ill just leave it be.
babyblueMX3
Post by babyblueMX3 »
I rarely saw somebody run with the vris while beeing boosted
Take those otu of there :)
RIP 400whp ZE-T MX-3
PATDIESEL
Post by PATDIESEL »
So you take the butterflies out, which bank do you use to run the intake of air through? I can't imagine using both banks...
babyblueMX3
why not ? that's what it does when both butterflyes are open anyways
and the turbo will compensate for the little loss in the lower rpm range
XxantwawnxX
Got this from a a site boosting a probe GT: So i gueess i tie them both open.
Intake Setup—VAF Placement/VRIS Plates Boost Start Full Boost
VAF before turbo, VRIS plates operating normally. 3800 RPM 4200 RPM
VAF before turbo, VRIS #1 tied open 3500 RPM 4000 RPM
VAF after turbo, no filter on inlet, VRIS plates normal 3000 RPM 3500 RPM
VAF after turbo, no filter on inlet, both VRIS plates open 2500 RPM 3000 RPM
Return to “Forced Induction”
