Cleaning headlight so easy?
JPEG
Post by JPEG »
I was looking at the FAQ to be able to clean my headlights, (because they are really brownish) and I was surprised that it was the outside that was dirty, not the inside. Did I understand well?
Thanks,
JP :)
bulaian
Post by bulaian »
yes it's most likely the outside, since thay are plastic, they tend to turn a yellowish colour. Just a few minutes of rubbing with plastic cleaner should clear them up again.
StylinMike
Post by StylinMike »
Hmm...i thought it was the inside too...sweet.
opdmize
Post by opdmize »
To really clean them up, softly wetsand them with 1200 sandpaper and buff them with rubbing compound followed by foam polishing pad glaze.
1993 MX-3 GS/SE KL-ZE'd
JPEG
Post by JPEG »
It took you maybe two minutes to write your phrases, and that's all I needed to be able to properly clean my headlights.
After and before: http://img.villagephotos.com/p/2005-3/9 ... dlight.JPG
To all MX-3.com admin and all their members, a big big thx! :)
Custommx3
Site Administrator
Post by Custommx3 »
The easiest way to explain why its on the outside is imagine a CD, if you run your Tshirt across it, it could scratch the cd with fine scratches right?
Imagine your headlights and road grime @ 50 mph.
I also updated the FAQ too with some stuff that I have used.
Return to “Appearance”
