Where have you guys mounted the crossovers for the front? I just got a set of 6.5" Kicker Components for the front and then 6.5" full range for the rear. I am wondering where do you mount the crossover at? Can it mount into the Metal of the door under the Panel and be safe or do I need to mount it somewhere else? Any places you have put em?
Thanks.
Crossover mounting placement
- justintoxicated
i would recomend mounting them on the bottom of those 2 plastic flap things in the hatch, behind the speaker grills...that is where i am gonna put mine anyway, it would be cool because they would be hidden, but if you wanted you could lift them to show off your crossovers. what are those plastic things for anyway?
Got Rice? You do!
- vozaday2000
i think he was asking where to mount them in the front, not the back. i mounted them on the outside so they were visible. but it seems like not to many people like that. you could just mount them on the door (metal part like you asked). basically you can mount them anywhere. you could make some fiberglass mounts to show off the speakers and crossover.
http://www.cardomain.com/memberpage/730367 - UPDATED!!!!!!!
'94 MX-3 GS KLZE, KL01 Cams, Fidanza Flywheel, Centerforce Dual Friction Clutch, WeaponR Ram Air, 2 1/4 exhaust, Nichi Neptune Rims, Toyo Proxy 45 Rubber.
lakersfan1
