the day as come my friends..20psi (1.36 bar) on my ZE-T
Man..don't give up on your car....after so much work, time and money....it would be sad if you let it go...it's a really beautiful car with an amazing engine setup.
I know how disappointing it can be...I'm on my 4th MX3...sold my 2 .5MX3 last year because it was give me a lot of headache.... and I'm still regretful...I just bought another MX3 now to "cure" my self
See yah!
See yah!
Cris
Babyblue... if you really had to, talk to BRC. http://www.brcpistons.com
They can make you a set of pistons (or say 2 or 3 if thats all you need) for pretty cheap. Just send in one of those wiseco's and tell them to duplicate it.
If you only need a couple, it should only cost a couple hundred dollars. I know it would suck, but to me its time that is important too not just money, and if its only a few hundred dollars holding you back, then you have invested WAY too much time to let that get in the way.
Last time I talked with BRC (they are VERY cool guys, mind you) a set of 6 pistons made to your exact specs (or wisecos, in your case) was $505.
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
- vozaday2000
Well babyblue, atleast you had some fun with it. I was telling a friend of mine that you were running 20psi, you should have seen his jaw drop. lol. oh well hopefully it is only the rings. looking forward to seeing some dyno slips when it is running again.
http://www.cardomain.com/memberpage/730367 - UPDATED!!!!!!!
'94 MX-3 GS KLZE, KL01 Cams, Fidanza Flywheel, Centerforce Dual Friction Clutch, WeaponR Ram Air, 2 1/4 exhaust, Nichi Neptune Rims, Toyo Proxy 45 Rubber.
Well, now what? I have the same problem when I boost at past 6 p.s.i on my turbo Kl. I think it's time to put the engine down again... I also had new pistons and rings, and every gasket and seal was also brand new, so I can't think of a worn out engine. I have detonation a couple of times, and I suppose that's what killed my top end.
European Mx3 GsRT
- babyblueMX3
are you using anything to tune timing ?
RIP 400whp ZE-T MX-3
Aww...man! That truly sucks BB. I have been watching your build up trying to get ideas. After I get back from New Orleans I'll have to really get in touch with you since you are the only one I know doing what I plan to do.
I'm going to NO to make some money and pay back debts. Then I'd say around 15-20k is going to be put into my car. I'm going to take a couple months off from any work once I get back and totally trick out my mx-3. I'd just like to get in touch with you once I get started to hopefully learn from your experiences. My goal is to have ~350hp and totally custom exterior and interior. I'm going to try and make a widebody kit. I haven't ever made a body kit but have done alot of fiberglass work making sub boxes and custom interior. I'm sure it won't be much harder.
Either way enough about me. I wish you luck BB and you better not part out your car you have spent way to much time and money on it. Cars are like life alot of fun times will be had and alot of bad times will be had. Either way you learn from it and better yourself and/or car. Don't give up on it you truly are an inspiration to the rest of this mx-3 'cult'
- babyblueMX3
I have done a compression test and all 6 cilinders show 170 psi, which is in range for what a Kl should give!!
What made my car smoke was the PCV valve, which was still connected in the stock way. I vented it directly to the atmosphere and plugged the intake manifold output and got rid of the white smoke clouds from under the car!! It went out from the equalizer piping, which was routed to the atmosphere. I had boosted until 9 psi and got no smoke!! Sorry for my happiness, but I was really scared!!
European Mx3 GsRT
i gotta know...
what EMS are you using?
20psi 370whp? t3t4 63 trim turbo? guessing.
what are you spooling at?
what where you making at say....15psi?
for a 2.5liter (and i must say this) that seems a lil low.
Dont get me wrong im sure it is an amazing ride!! and i bet you spool at 2500rpms.
oh and im shocked the tranny is taking 370hp
impressive but at 20psi i would think you would break 400whp.
now im not trying to piss anyone off and i admit im new to the mx3 but i have turbo'd an integra GSR and a miata 2 times and im working w/ a rotary setup now. So im not some kid saying..."awww you suck" NOT AT ALL!!! Keep going with it!!!!!
Im looking into a dual turbo setup maybe something staged on a kl-de or ze (ze first and DE after i mess up tuning)
Garage (sort of)
99 Acura Integra GSR-T (totaled)
03 Mercedes Benz C230K (rear upgrade from 3.27 to 3.67 ratio) running strong at 108K miles
92 MX-3 v6 (that i wanted to twin turbo w/ an ht12 and ht15) - Parting out now!!!
90 MX-5 getting the rotary treatment
bdavis2005 @ gmail . com
feedback link -> http://www.mx-3.com/phpBB3/viewtopic.php?f=37&t=62911" onclick="window.open(this.href);return false;
after looking at some dynos a bit on car domain i must say 370 is the best i found but i still want to know what turbo and EMS you are using.
and tuning by ear??? kinda crazy.... second the wideband went i would have walked.
oh and 20psi on a ZE DAMN what was that compression ratio like 14:1? or 15:1??
Garage (sort of)
- babyblueMX3
I'm running on a t3-t04e 57 trim upprading soon (either sc61, gt35r or t66).
I'm expecting over 400whp on 20psi..just haven't dynoed yet. and I'm on a rough tune. The WB gave crazy numbers so I couldn't use it really.
I'm running on 8.7 compression ratio pistons. not the 10:1 on the stock ze's
I'm running full megasquirt n spark for tuning.
- fieromx3
u should get stage 4 cams or stage 3-turbo to compliment that high boost ur puttin out and maybe ferrea oversize valves anythin stock u should replace with aftermarket to get MORE POWER!!!! u gotta get that on the dyno and DEFINITELY get to the track with some slicks i wanna know the times u can run. do u currently have an lsd? as far as turbo presicion makes some good turbos i had priced a turbo rated for 680hp and it was a 360 bearing turbo full t4 and it was like 850 bucks! really good price compared to hks or turbonetics.
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
14.4 @ 96.7
14.5 @ 97.2
- babyblueMX3
haven't got a lsd yet but working on that. I'm purchasing mazdapeed slicks he had for sale. Stock valves flow plenty enough so I don't see the need to change them. It's pretty much the only thing stock on the engine.fieromx3 wrote:u should get stage 4 cams or stage 3-turbo to compliment that high boost ur puttin out and maybe ferrea oversize valves anythin stock u should replace with aftermarket to get MORE POWER!!!! u gotta get that on the dyno and DEFINITELY get to the track with some slicks i wanna know the times u can run. do u currently have an lsd? as far as turbo presicion makes some good turbos i had priced a turbo rated for 680hp and it was a 360 bearing turbo full t4 and it was like 850 bucks! really good price compared to hks or turbonetics.
As far as turbos are concerned I got this thing covered
as for the turbo ,im going to recommend the T66. Affordable and maxes at about 500whp. If you want to view compressor maps i find majesticturbo dot com to be a good site for viewing. (never bought from them but spoke to kevin there a couple times... didnt have my turbo instock)
8.7:1 sounds right on! so your compression at 20psi was at about 14:1 (very rough guess) my point- DAMN that is alot of boost!
so- question for you and i think many would like to know your input as builders. considering the piston and rod swap you did on the 2.5L .... do you think is it a good idea to get 3-4 kl-de's and build them or ONE kl-ze? Also considering the nightmare people have when they get send a DE that an importer is passing off as a ZE.
Garage (sort of)
Oh and i looked into this MEGASQUIRT. Am i reading this correct? fuel mapping...injector control, throttle responce...ect 269.oo?
i have used LINK systems and worked with Haltech and now i have Microtech for my miata. How does this compare (megasquirt) timing,knock, alarms...ect.?
off topic (i know) ... please feel free to email me if you want to bdavis2005 at gmail dot com
or
keep the thread going so all can enjoy
Thanks, Bryan
or
Thanks, Bryan
Garage (sort of)
