J-Spec bumper and lip installed
- jschrauwen
Jeremy did your's come with the J-Spec re-bar too? How was it making the electrical connections to the headlights and foggies - in other words did you have to do a lot of improvising or was it mostly plug n play. It would be nice to know ahead of time before I do my install this weekend. Perhaps you can pm me your ph# and we could talk more on this. Thanks.
*John*
*John*
- jschrauwen
- MAZDASPEEDMX-3
- papa roached
the bottom if a lip just like ours, i didnt have the j-spec rebar, wish i did, it was just a bolt on affair, if your using us-spec rebar you gotta cut the corner off the bottom next to the fogs, it pushes in the hole for hte fogs a bit
- jschrauwen
Thanks jeremy. I do have the J-Spec rebar, so I guess there's nothing to cut. Are you making your own wiring config for the foggies?papa roached wrote:the bottom if a lip just like ours, i didnt have the j-spec rebar, wish i did, it was just a bolt on affair, if your using us-spec rebar you gotta cut the corner off the bottom next to the fogs, it pushes in the hole for hte fogs a bit
- papa roached
ill have to, i wish i had the j-spec rebar ![Sad :(](./images/smilies/icon_sad.gif)
- jschrauwen
Might as well keep the same subject matter in the same post. I hope you don't mind Jeremy. Pics of mine installed with J-Spec rebar, lip, and foggies.
![Image](http://img360.imageshack.us/img360/6650/jspecbumper15nn.jpg)
![Image](http://img360.imageshack.us/img360/5702/jspecbumper21tq.jpg)
![Image](http://img360.imageshack.us/img360/8494/jspecbumper35pp.jpg)
![Image](http://img360.imageshack.us/img360/3623/jspecbumper44ca.jpg)
- jschrauwen
Thanks Jim .... and sorry .....neutral wrote:That really looks xlent John (and Jeremy). I'm jealous of both of ya. fwiw John, you beat me to the buy, but not by much...
Perhaps Matt (kiwi_mx3) could put an extra front end in his luggage on his next trip to the US and Canada from NZ ...LOL. I wonder if he'll be job hunting then.
- papa roached
he needs to put a extra crash bumper in there for me, looks good man, sorry i havnt been on here much lately, not mad at you just had alot of stuff going on in my life, i love the JDM look so much, i want your skirts SOOOO bad, wish someone would make copys of them ![Crying or Very sad :cry:](./images/smilies/icon_cry.gif)
- Josh
is there alot of intrest for them? as i have just picked myself up a set recently. i was stroling threw the wrecking yard and off in the corner i spotted a black mx with the sides. i had to have them and on the credit card they went. the card is for emergencies onlypapa roached wrote:wish someone would make copys of them
but i could look into makeing a mold of them and maybe produce a few sets. i havent painted them yet so i could do it. let me know and i could set up a GB or something.
- papa roached
are they like the ones he has on his car, there are two different styles, the JDM style has a flaired end like the ends of the lip, i know i would be down for a set though
- jschrauwen
- Josh
the sides i have are the North America spec. whats kinda wierd is they actually say Eunos on them.
but if there are enough people intrested i could look into making some molds.
