YES YES KF MX3 BACK ONLINE(long)
YEAH w00 i am so happy...words cant describe..anywho what was wrong? well you see there is this STUPID ground wire comung from the harness that should go to the valve cover BUT I did not have ground to that... so no power to disty..just a painfull spark after shut off... i replaced the coil relays 18 dllrs eash :S because 2 seemed to be burned and I think they were... by accident connected the wire and I didnt think it was even gona start...so i hit the clutch..the key andBROOOOOM i was like WTF it started? i was stumped... then i saw it was the wire Installed radiator connected wires. All i need to do is just bleed brakes and clutch. I gurss i have vacuums wrong because the vris solenoinds wont open but thats easy to fix Ill do it tomorrow in time. Ill be dumpiong my projectors and making new ones and fixing her up good. Dont wanna brag but dayum..i rewired the whole engine memorized every single sensor there is to this car... all in about a week and a half... i cant belive i did that o.0 but yeah zoom zoom is back...bye bye civics (i dont street race) Thanks to everyone that halped me !!
as far as partsm i need..i guess i just need water resevoir.. speed sensor is rewirable and wiper motor worls..even if its all carbonized...it works fine.. ill still replace it and of course first thing im getting? FIRE EXTINGUISHER..
-hec
- Aston Wards
- mitmaks
nice job
- vozaday2000
awesome!!!! congrats
http://www.cardomain.com/memberpage/730367 - UPDATED!!!!!!!
'94 MX-3 GS KLZE, KL01 Cams, Fidanza Flywheel, Centerforce Dual Friction Clutch, WeaponR Ram Air, 2 1/4 exhaust, Nichi Neptune Rims, Toyo Proxy 45 Rubber.
- relisys_3200
- ovendenk
congrats man!
kevin (aka The Oven)
93 mx-3 GS KL-ZE with KL31 cams and properly chipped ecu
All mods are on my website: http://ca.geocities.com/ovendenk
MX-3.com Worklog: http://www.mx-3.com/phpbb2/viewtopic.php?t=48462
hmm that overflow tank leaks water..i bypassed it but i dunno...i wonder if it would kill my car to not have it..considering wintertime is coming?? im assumoing its safe?
-hec
- PATDIESEL
No you need it. A car can run hot even in the winter...
For 6.00 what is the issue? It only takes ten minutes to install the Autozone one. I have it and it works well and the bracket gave me all kinds of mounting options.
i got it for 30 dllrs... i dont mean the water overflow resevoir..i mean the bottle.. that black thing stuck to the radiator..i ran the car and its nice but i dont know its missing that poull that the kfze has after 5k rpms.. the vris solenoids are opening right, using the kf ecu.. unless i was running bad before. I did not install the solenoid that provides vacum to the fuel pressure regulator.im using de injectors and am using the k8 fuel pressure regulator..im guessing thats the same as the klde.. ?
-hec
