I'm wondering if that's part of my problem, maybe my power hesitation I'm experiencingfieromx3 wrote:i have my vris tied open and i didnt notice anyimprovent of any kind so i dunno if it would work for you.Nd4SpdSe wrote:I would love to go, but I don't want to embarass myself...unless someone knows how to tie the VRIS's open, I wouldn't mind giving that a try. I'll get new spark plugs too this week.
Track
- babyblueMX3
nope problem was I just found out..I was running way too much timing, believe it or not If I had stayed at 20psi I would be ok right now, it's because I dropped to 16 that the rings went (timing map wasn't made for it).jschrauwen wrote:babyblueMX3 wrote:sorry John won't be there..my engine is like..hrm...in a bad shape right now..probably a piston/ring or valve seal that went on me..I think it's more of a ring problem. I spare you the detailsjschrauwen wrote:
I wonder if BabyblueMX3 will be there?Oh Nooooooo!!! One too many pounds?? Actually , saw your PT post after I posted this. You're hoping your smoking problem had to do with the PCV valve. Too much internal pressure within the pan, crankcase etc??? Your lowered CR might be letting that excess pressure by. Gotta release that excess pressure somehow.
so now I'm not sure if I'm fixin or partin out
RIP 400whp ZE-T MX-3
- Too much Time
- mymx.3
I couldn't go on Sat anyways ... wedding ... but Fri and Sun I could
I don't think anyone else is interested unless John was still going .........
- Too much Time
- jschrauwen
i'm planning on going to cayuga on friday. i WOULD hit shannonville, but its twice as far in the opposite direction, and i'v gotta get up early on sat to head out.
i'd actually b able to get to cayuga by the time they start things after work
trevor...wanna give it another shot? (DON'T do a burnout!)
