exhaust next week need specific size PLEASE :)
ok.. heres the deal...appointment is for next week... i know im moving pretty quick but oh well its good reliable cheap labor.. I need to know what size piping should i use after the kat converter as far as exhaust..not using headers yet... the engine is kfze 2.0. I have not kat converter ..obx muffler and i still have that stock additional muffler. I dont want it to loud and i dont want to loose power as I do this..anyone got any equations I can use? or even beter specific pipe diameter? 2.5? 2.0 ? What do I do with the additional little muffler that is in the middle of the system? remove it? I dont need to worry about emissions. Any help is very well appreciated and Im sure your mx3 will be blessed with tons of neat mods ![Very Happy :D](./images/smilies/icon_biggrin.gif)
-hec
so 2 1/4??
-hec
ok ill do that
so if im not at around 170... i would gain lets say..um 5?
-hec
- jschrauwen
Hector, I think you already know the answer. Look up Tatsu's thread wrt Magna Flow - tons of info. IMO, 2.25 with Magna Flow Cat, pre-silencer and muffler. You'll probably come out with that after going through that thread.
- solo_ryder
I know I may be among the few...but i think the pacesetter 2.25 cat back is the way to go. Its Cheap, should last a few years, and isnt loud at all unless you really romp on it. I currently have a DE with obx headers, a magnaflow cat, and a modified pacesetter set up and its awesome( i say modified because I have to cut some of it due to the headers being longer then the stock exhaust) This setup has been on my car for about one and a half years and the only rust is on the welds, but there is no rust on the inside of the exhaust, only surface rust. Also for 180 dollars shipped to your door thats hard to beat. When Im on the highway I dont hear the exhaust which is what matters to me because I drive all over the place. Good luck in whatever you choose, but yea I def think 2.25 inches is the way to go
93 GS-DE,mx6 tranny, obx 2nd gen headers, highflow cat n 2.25" catback, 65mm tb,CAI, mazdaspeed mounts, SPEC Stage I clutch kit, new K8 flywheel, SRD C.A.B., Intrax, S.T. braces
http://www.cardomain.com/memberpage/698108
thanks! i really appreciate all this usefull information
one last thing..should I delete that silencer? (second muffler) or keep it?
-hec
I used a 2.5" crush bent system with a thrush chamber muffler. It is a nice (stealthy looking) system, although a bit loud w/o a cat.
I ran 13.05 @ 109.5, so it flows plenty.
I'm going to sell the system for like $80+shipping. So like $120 or so shipped. Any takers?![Wink ;)](./images/smilies/icon_wink.gif)
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
Have you got any sound clips that you can send me?schuttie2002 wrote:I know I may be among the few...but i think the pacesetter 2.25 cat back is the way to go. Its Cheap, should last a few years, and isnt loud at all unless you really romp on it. I currently have a DE with obx headers, a magnaflow cat, and a modified pacesetter set up and its awesome( i say modified because I have to cut some of it due to the headers being longer then the stock exhaust) This setup has been on my car for about one and a half years and the only rust is on the welds, but there is no rust on the inside of the exhaust, only surface rust. Also for 180 dollars shipped to your door thats hard to beat. When Im on the highway I dont hear the exhaust which is what matters to me because I drive all over the place. Good luck in whatever you choose, but yea I def think 2.25 inches is the way to go
I dont have any with the new engine cause my camera has been forked lately. Ill see if I can borrow someones and then Ill tyr to post a few clips
- jschrauwen
Here's a couple of pics of those Magna Flow items that Tatsu identified;jschrauwen wrote:Hector, I think you already know the answer. Look up Tatsu's thread wrt Magna Flow - tons of info. IMO, 2.25 with Magna Flow Cat, pre-silencer and muffler. You'll probably come out with that after going through that thread.
![Image](http://img360.imageshack.us/img360/1755/exhaust29fp.jpg)
![Image](http://img360.imageshack.us/img360/4827/exhaust18hh.jpg)
Hope this helps.
*John*
