Throttle body cleaner...
- MX-3 Money
Is there such a thing, I thought I saw it at Canadian Tire once but didn't see it today. Now I saw carburetor cleaner but I thought I heard that its to harsh for TB's? Maybe not?
1993 MX-3 GS 5 spd, KL-ZE swap, kl31 ecu, 110 amp alternator, Unorthodox Underdrive Pulley, SSautocrome headers, High flow cat, Pacesetter high flow cat-back, B&M shortshifter, Clear Sigs/Sides.
- jschrauwen
- PATDIESEL
It works well too, but careful the car will run like crap for a bit. Don't get scared it will go away after a day at most.
yeah i used the TB cleaner on mine and after driveing for a little bit the car was acting normal and didnt have sticky s--- in the intake
CTC Racing
92 1.6L
93 323 Tranny, ACT clutch, Exhaust, cold air intake, MSD Blaster 2 coil, MSD 8.5mm super conductor wires NGK V-power platinum plugs,engine dress up,custom interior(almost done), GS front bumper, GS 5 spoke wheels Painted white.
92 1.6L
I completely took the whole im off and sprayed it with carb cleaner..left it clean to the metal except nthe areas that are hard to get to (v6) There was a littloe piple that 9i sprayed a couple of secs and alot of black stuff came out. Also i installed an oil catch can just in case.. so now that I did my swap I noticed the engines valves are CLEAN..
to bad the engines fate is to sit there and do nothing until my engine dies... or i sell it.
-hec
yeah it really is o.0 i mean besides it should be clean.. to burn fuel more efficiently. You will notice more mpg. Also clean valves are a beautifull thing! Make sure you clean the passage where the pvc valve goes trough and well everything. If you spray it with carb cleaner it will leave it as a metal finish and well look new. Takes around 1 hr to 1.5 hrs . Its quite simple to remove im and reinstert.
-hec
