Okay, my top suspension bushes seem to have gone, the ride is very bumpy and im pretty sure that on the bumpy roads here my suspension is taking a hammering.
Symptons are
Knocking noise coming from the top of the suspension towers at the front.
Very Bumpy Ride
Solution
New bushes/Mounts.
Can anyone give me information on where to get these...someone mentioned SRD does them, but on checking the site i could see them anywhere.....
does anyone recommend a particular supplier, or should i just stick with the OEM stuff?
Suspension Mounts
- PATDIESEL
I think OEM is the only supplier of the upper ones. However, I suggest replaceing the bushings b/c I have never seen a "bushes" on a MX-3. hehe
Have you checked Mazdaspeed Motorsports?
I know they make them for the BG Protege. 40% stiffer than stock. Fronts would fit, unsure about the rears if none are available for the MX3.
THINK FAST, GO RACING!!
2004 Mazda6 Wagon
2004 Mazda3 Sedan
1990 BG8P Protege LX - KLZE - Race Preped - #98 SM - SCCA Solo2
![Image](http://www.imazda.com/mazdaracer/sig_pic_mx3.jpg)
2004 Mazda6 Wagon
2004 Mazda3 Sedan
you need to have an account with themMazdaracer wrote:Have you checked Mazdaspeed Motorsports?
- hppwdn
Tirerack.com sells the replacement strut mounts. That's where I got mine.
