ebrake help
- ooELMOoo
ebrake help
Just recently my ebrake light has come on....its off untill i accelerate then its stays on til about the end of third gear???any surgestions????
| CUSTOM X3|
| CUSTOM X3|
- cjthor
Re: ebrake help
You are low on brake fluid!ooELMOoo wrote:Just recently my ebrake light has come on....its off untill i accelerate then its stays on til about the end of third gear???any surgestions????
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
hey I have the same problem I disconnected the piece that sends the message from the handle but to my suprise it still stayed on I have plenty of fluid but I am doing a jdm cluster swap so I am just going to remove the bulb to fix that issue. Other than that I have no Idea why it does it or how to fix it.
Teal 1993 MX3GSZE
- PATDIESEL
Instead of removeing the sensor from the E-brake handle itself, try unplugging the wire at the resevior. It may have fouled and that is why the light is staying on. If it goes out then plug the handel wire back in. Then get a new sensor so that you'll know when the fluid is low. It could save your life.
