Distributor for 1.8L
I need a distributor and the mazda dealer in edmonton says it will cost $700. If I did the klze swap now would the engine I get come with a distributor?
thanx.
thanx.
Labor? Can they break up the labor cost into seconds? If it took a skilled mechanic more than 10 minutes to install this distributor, he should have to take a short yellow bus to work everyday.bulaian wrote:I had to get mine replaced in december. Mazda Dealer here quoted me $850 for parts and labour. I ended up buying a new one with labour included for $500
- PATDIESEL
They charge the labor by the hour and they have a book that sais how long the job should take. It the book sais one hour and it takes 5 minutes they still charge for one hour. However, normal mechanic rates are about 55 and hour so it sounds like they are charging 2 hours for the job. That is sutpid cause like Lakers said it shouldn't take ten minutes to und two bolts and replace the disty.
However, Lakers, where did you find a remanned disty for 160.00? That is super cheap...
Autozone. A couple people had said they had a couple failures with thier remanned distys from them, but mine has been in two years, and still runs like a champ (knock on wood).PATDIESEL wrote:They charge the labor by the hour and they have a book that sais how long the job should take. It the book sais one hour and it takes 5 minutes they still charge for one hour. However, normal mechanic rates are about 55 and hour so it sounds like they are charging 2 hours for the job. That is sutpid cause like Lakers said it shouldn't take ten minutes to und two bolts and replace the disty.
I found a distributor for $400 new. The mazda dealer in edmonton charges $80 an hour and I had my car towed there so that sucks. I was reading the v6faq and was interested in the permanent dist. fix by
Gro Harlem. Instead of the hei ignition module I was thinking of getting an msd ignition control box. Anyway definately amazing work by Gro![Very Happy :D](./images/smilies/icon_biggrin.gif)
