Distributor Mod.
lastkiwi
Distributor Mod.
Post by lastkiwi »
Iv'e got only a very weak spark & can't start. Prior to this the egine would just diie on me but could start again . Gradually got worse.
Everything points to the usual MX3 Dist. failure so I'm going to do the Dist Mod outlined by Grow Harlem.
The instructions don't mention anything about disconnecting the failed part. Is this necessary & where in the Dist. is it?
Colin - down under.
Colin ---- down under
accordionservices@xtra.co.nz
babyblueMX3
Post by babyblueMX3 »
mm I think it DOES mention to disconect something in the disty..check it out again. or I might be blind..but I really thinkg I saw it there
RIP 400whp ZE-T MX-3
lastkiwi
Dist Mod.
Post by lastkiwi »
No the only thing it says about disconnection is REMOVING the STRAP to the COIL.
I'm not doing the COIL REPLACEMENT part ,just doing the first stage & that is putting a 4 pin HEI in the system EXTERNALLY.
So do I remove the internal one or just cut a strap ?
Hope this is clear as I"m still a bit in the dark over this one.
Colin - down under.
kiwi_MX3
Location: Backpacking in Canada in vancouver 13march onwards
Post by kiwi_MX3 »
Colin its the coil thats dying or died in your dizy have you tested
it to see what ohms it is...
2fazed
Post by 2fazed »
His write-up says to cut the straptothe old coil, inside the disty. That's the main reason for Mx3 disty failures. I don't believe it will work by just hooking up an external HEI module.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
Rick Johnson
Post by Rick Johnson »
You will need an external coil as well, I'm am currently in the middle of this process myself.
hgallegos915
Post by hgallegos915 »
I just posted on this.... it will work with external hei.. i think.
-hec
lastkiwi
HEI Module
Post by lastkiwi »
I,m putting the Hei [ Wells D100 ] in my Mxs tommorow. All the postings I have checked out in this Forum say that it is the module that fails. That is where I,m starting anyway so will know tommorrow.
Colin - down under
Gro Harlem
Post by Gro Harlem »
YOU DO NOT NEED AN EXTERNAL COIL TO DO THIS MOD!!
Damn doesn't anyone read the how-to?
It has two procedures: one for doing it with external coil, one without
The only part i gotta edit is the part wehre i say "splice into the 6th disty wire" b/c u apparently are supposed to just cut the wire not splice
DONATE TO MX-3.COM
killerpickle
Post by killerpickle »
Say what?
We are supposed to cut one of the wires? I've been having some issues past 110 km/h (engine cutting out like before except not as bad.) is there something you want to change from the initial instructions for an HEI mod, without the external coil?
Tom Alexander
killerpickle
Ok, I read the PT forums and went ahead and cut that wire. Now Im going to take it for a cruise to see if I can go past 110 for a few minutes.
Tom Alexander
hgallegos915
have you noticed that most oif our faqs habe weird characters and are a bit hard to undertand by me :( i wish it had pictures LOL
-hec
killerpickle
Okay, I just got back from the test. I took the car up to 150 and held it there for about 5 minutes. The car did not cut out. I cut that 6th wire, and now the mod works fine. Prior to this, I was unable to steadily go past 110km/h. I though for sure I had a faulty external HEI or that the connections were not good enough. Turns out it was just the fact that the old, faulty one was still connected in tandem.
Now, my question is how did no one else have this problem if they followed the instructions that gro made? Are we just now learning that the 6th wire needed to be sliced, not spliced? It makes sense to me, and I always wondered why we would leave a broken HEI connected.
So I guess we need to update the FAQ. Great mod though!
Tom Alexander
lastkiwi
HEI Module
Post by lastkiwi »
IT WORKS !!!!
Thanks all for your input. My MX3 would not start at all so I guess the part has died completely.
I did the MOD. today . Turned the key & it starts perfectly.
I haven't cut the sixth wire .
If I have to cut the sixth wire WHERE DO I cut it?? Do YOu have the wire connected in to the LOOM or connected into the DIST ?
Colin - down under
killerpickle
It seems to me, from my experience. That the mod without cutting the wire only helps things a certain amount. When the cut the wire, it runs perfect. I cut the wire 1" from where it enters the harness.
Tom Alexander
