US MX-6 Engine + ECU + VAF setup?
I have a US MX-6 engine and i was juz wondering wat is the best ECU + VAF setup for this?I kno its posted all over this forum but im a bit confused wit all these kl36 kl31 kl01 kl02 kl03.so can any one help me out here?
KL-DE + KL02 (VAF) + KL01/KL02/KL05 ECU
KL02 looks like the JE50 has the same connector but sends other readings voltage-vise.
92 GS-R, RX-8 Lightning Yellow, Complete Aresspeed Bodykit
http://www.cardomain.com/id/tocixxx
Mazda Speed & Style Club Austria http://www.mazdaclub.at
What's important is that you get the VAF and ECU from the same kind of car it came from. it's simple... that motor worked properly in the other car with the VAF and ECU that was also in that car... You'll be very happy with that setup. I recently completed my ump-teenth one of those swaps, and each one is more and more fun... Good luck!
Daniel
Daniel
--Maybe the Hippopotamus was just a really cool Apotamus.--
- hppwdn
The KL31/36 ECU is the KLZE which was used with the JE50 VAF in Japan in the MX6. The US Spec ECU uses a KL02 VAF.
I was actually running an American ECU with a JE50 on my ZE for a week or so before i remembered I had to swap the VAF. It seemed to work fine. I've got a Megasquirt so I'll be removing the VAF completey in a week or so.
Post on the for sale/trade forum or check on http://www.mx6.com or http://www.probetalk.com for your best bet... it's likely you'll find one much less expensive there than at a junkyard. Good luck!
Daniel
Daniel
This is correct only in the upper (i think at 6000) RPM-RANGE the KL02 ECU used with JE50 is running lean ! I was running this setup on my ZE for a while.hppwdn wrote: I was actually running an American ECU with a JE50 on my ZE for a week or so before i remembered I had to swap the VAF. It seemed to work fine.
- jschrauwen
That should work. Until I got my KL31 ECU I ran the MX6 set-up - KL01 ECU with the KL02 VAF.tk2269 wrote:so i can also use the ecu and vaf from a probe gt ryte?
- jschrauwen
[/list][/quote]tk2269 wrote:i have a white primed 92 mx-3 gs and a Yellow 92 mx-3 gs-94 mx-6 LS motor,still looking for ECU and VAF.i cant find any on mx6.com or probetalk.com.Anybody have the ECU and VAF for $100-200?[/url][/list]
Check again on PT for the ECU and VAF. Place a [WTB] "want to buy" in the for sale forum here if you like.
